Imaxb6 quickie
Low
142
42
46
England norfolk
Quick question, my imax beeps at about 4.08... I then start it running again, it generally takes another 30 minutes and beeps again at 4.2, after adding at least another 150mah!!... Battery issue or cheap imax issue?
Or both!
5,786
Sounds like the configuration option that cuts the charger after 5000 mAh of charge or specified time.
5,786
Mine are set for 9990 mAh now because the capacity of my packs is 10000 mAh. It is a security feature to prevent overcharging and is was set to 5000 mAh on all my chargers of different types by default.
Low
142
42
46
England norfolk
Im only charging a cell at a time tho so may have to look else where for the problem, thanks for the advice tho all goo learning.. When iv finally built this battery 10000mah it is :)
You can make it beep and stop after a fixed time and/or a fixed amount of charge. You need to set those two to realistic values for the battery you're charging and whether you want to check its state at any point during the charge.
Low
142
42
46
England norfolk
Not sure if that would do it the imax says 4.2 on its screen then on remaval and restng the are below, could always set for 4.21, trust my volt meter over the chinese knock off
Try testing with your voltmeter while the charger is connected and the screen on. That will confirm whether the screen is showing the same voltage.
5,786
Search for "imax calibration" on Google and you will find the correct procedure to calibrate the charger. My chargers are off by about 0.6V, the battery comes off the charger at 40.9 V, except in balance charge mode where they are spot on so I didn't bother calibrating them for normal charge mode.
