Hi all.
I have a Bafang SWX02 motor left over from an old kit that I used to have, and I recently bought a new Kunteng (KT) sine-wave controller for it. However, stupidly I did not check the compatibility of the power cables. The Bafang has a 9-pin connector, and the diagram for the controller shows that it has a 'three-phase' connector. I'm not sure if I've got the wrong end of the stick, but it seems that these are my available options:
1. Buy some kind of converter to match them (I havn't had any luck find anything so far).
2. Buy a new motor with a 'three-phase' connector, and then later a new controller with a 9-pin connector (do these exist?) for a separate ebike build (I plan on building more ebikes in the future).
3. (this is the option I'm dreading) Something involving cutting up the cables, and building matching connectors. I'd rather aviod this option, as like I said above, I plan on doing more builds in the near future, so don't mind buying new components.
I hope this makes sence. I've also attached an image of the connectors on the motor and controller. Thanks!
