I haven't bought one yet but it's going to be a 250w mid drivewhat motor is it ?
Ah that's good news then, I'm not bothered about speed just pulling power, I have been thinking about a bafang too. Thanks for the info.under 15mph a motor can pull way more wattage than 250w more like 800w-1000w when climbing steep hills.
my old bosch performance motor with 60nm of torque was good enough for everything i went up.
tho if you want to change power settings ect then baffang is the only option as bosch shimano Yamaha ect have locked software you can add a dongle to remove the speed limit but thats about it and wont give you any more power.
KirbEbike Vapour full suspension eMTB (FULLY BUILT BIKE)
KirbEbike Vapour full suspension eMTB (FULLY BUILT BIKE) KirbEbike Vapour KirbEbike Vapour full suspension eMTB (FULLY BUILT BIKE)www.cloudsto.com
Wow very cool, it's a bit out of my abilities at the minute so I may have to ask you some advice on this at a later date. Thank you for the advice.my bike with a dongle can do 35mph on the flat if i spin the cranks at 120rpm but is geared for this speed.
if i want better climbing then i fit a smaller sprocket on the front so would go from 21t to 18t or run dual sprockets.
tho you cant do this with the new motors but you can fit a smaller chain ring to gear the bike how you like it.
