Individual cell resistance
Garry Hallam
104
10
What I am wanting to know is if it is possible to check each individual cells resistance once it is part of a made up pack?
Is it just a case of touching onto that cells + & - or do the other cells connected influence the value?
2,835
You won't measure a cells resistance with a conventional meter. A meter's resistance settings are for measuring 'passive' resistance; the voltage from the cell will totally confuse things.
The only way would be to measure the voltage across the cell when under load. Unless you knew the exact load current that wouldn't give an absolute measure, but if you measured all the cells that way any 'bad' cells with high resistance would stand out as having a lower voltage than the others.
3,981
You need one of these type meters. You can't measure any cells that are in parallel, except as a group because any current will take a path through all cells in the parallel group.
Garry Hallam
104
10
I had this in my Amazon cart. Looks like the same thing
3,981
