Is the 1:1 the pedal hall sensor?
Michael Love
155
35
58
In my new ctrllr I think the 1:1 is the pedal hall sensor, anyone agre
And what is an electric brake?
Andy-Mat
2,214
562
77
The brake sensor is for modern e-bikes, the brakes have a switch in the lever assembly, that when activated (usually a low signal), immediately shut s off the motor.
I have no opinion either way about the 1:1, myself.
regards
Andy
Ajax
311
29
Here's a link to e-bike brakes just so you known what they look like.
It has a switch inside which cut out the motor, it also takes the normal break cable.
https://www.amazon.co.uk/Electric-Wuxing-Handles-Quality-Tricycle/dp/B01HO08JAQ/ref=sr_1_6?ie=UTF8&qid=1544390698&sr=8-6&keywords=electric+e-bike+brake
The 1:1 looks like the PAS sensor cable, its the one thing not mentioned which ought to be there. Here's what one of those look likes.
https://www.amazon.co.uk/L-faster-Electric-Cycling-Accessories-Assistant/dp/B01MXH67CA/ref=sr_1_3?ie=UTF8&qid=1544390986&sr=8-3&keywords=electric+e-bike+pas
8,225
8,225
Electric brake might Chinglish for Regen, just ignore it.
Michael Love
155
35
58
Thank you all for your help. Turns out Amazon seller selling same thing, but without the display wires, and for some reason cruise wire is looped like the electric lock in this pictyre. So all i gotta do now is turn the assist hall sensor on this controller into female, anyone know of any way to do that?
Thanks again.
5,785
Thanks again.
Cut male plug and solder in female socket. Been there, done that with my last controller. Not just for the hall sensor plug unfortunately :(
8,225
Connectors are SM 2.5mm, look on ebay for them. Available in pin count you require.
