Kit fitting
pea
59
13
Hi, I was wondering if anyone has any idea of what the average cost of fitting a kit would be?
Pea
peerjay56
745
199
Nr Ingleton, N. Yorkshire
Pea
That would depend who does it;) I'd do it for a crate of beer, but a cycle shop, assuming they agree to do it, will probably charge by the hour. And I bet they'll take a few hours:eek:
Alan Quay
2,341
1,073
Devon
Will work for beer also.
Simple kit should take about 1 crate, complex would could be up to 4 crates.
pea
59
13
The email just said to supply and fit the kit it would be £949, the kit is £800.
I'm starting to swing towards leaving this bike as it is and buying a new bike. I've got my eye on a couple :)
Pea
amigafan2003
1,389
139
Sounds about right 4 hrs work @ £40 per hour.
My rate is £30 per hour, but I don't have wages or a shop to pay for ;-)
pea
59
13
The kits the oxygen one, I actually don't think the bottle battery will fit on the bike I have. I had thought they had more than one kit, they could do for all I know, that's the kit they've mentioned in the email.
I'm looking at a cyclotricity and a woosh bike. I'm thinking that I'd be better off spending the money on a new bike rather than £950 on a kit.
The Oxydrive kit is pretty good. It can be de-restricted to go quite a bit faster than most. It looks nice too. It takes about 2 hours to fit for someone that's done one before. £150 is too much. Most dealers charge £100 for fitting that kit.
You still didn't say what bike it is. Tell us or show a photo, and I'll tell you if it fits.
trex
7,703
2,669
this one may suit you:
http://wooshbikes.co.uk/electric-bikes/sport-ts/
£725 with torque sensor. If you don't like it, send it back within 2 weeks.
pea
59
13
One of the bikes I looked at on there was the sirocco, I'm 5ft 2 so it's the height of the crossbar that's a problem.
trex
7,703
2,669
you definitely don't want the battery in the back (sirocco), it makes swinging your leg over the rear wheel to get on to the saddle much more difficult.
It's a specilized myka, it's only a 15 inch frame tho :D
I doubt that the Oxydrive kit would fit. Maybe that £150 for fitting includes cutting and welding your frame. Then the price would be nearly justified.
There's bottle batteries that come out sideways. You'd probably have room for one. here's the dimensions if you want to check:
pea
59
13
Thanks for that, I'll use that to check the sizes. I'm thinking that a rack battery is probably going to be best for the bike.
They never asked what bike the kit was for to be honest.
Pea :)
pea
59
13
Thanks for the link.
Because there's not a hope in hell of me fitting the kit and if £150 is the rate to fit one I'm starting to wonder if getting an ebike is going to be the easiest route.
trex
7,703
2,669
yes, pea. Kits are great for people who have the right tools.
generally, the water bottle cage lugs in the donnor bike are not made to support a water bottle batter that weighs 3 kgs and the forks are not set up for a 4kg front wheel (in case you buy a front wheel kit).
economically, if you have to pay for fitting, you have lost the equivalent saving by using a nil cost donnor bike.
