Hi all,
First off, good to meet you all and this is my first post as a new user on this forum, and hopefully many more to come!
I have recently embarked on a custom scooter build, for my son, who, affectionately calls it, the "Batscooter" using parts from an ebike which have been sourced recently. The doner scooter is a kugoo S1, with its original motor, however the battery is now 48 volts 750 Watts, and is using a KT48/22 amp controller and so will be somewhat punchier... if I can get the throttle to work by itself...
I'm pretty new to the world of Ebikes and scooters but fell in love with them since the aformentioned scooter was purchased a little while back. I've since ridden it and a Mercane Widewheel, as well as my Voilamart converted Bike almost daily, without fail!
However, I am completely stumped with a system, that seems to work perfectly, bar the throttle only settings. Below are the components and some of the customisations I have made.
A KT-LCD8H display...
A KT-LCD8H display unit (configured, to my understanding, throttle only)
Various throttles... BUT with the rewiring of the connector's as shown below... (all tested for current and no dry connections etc...)
The frustrating part is that when holding the down arrow down, for walking assist, the motor spins up beautifully and without fault to the ~6kph limit...
But when trying the throttle only, no matter the settings I seem to use, it seems to recognise a throttle is present (I take out the signal wire or switch it to another wire and it throws an error up)
I have read threads saying it can work without the PAS fitted, but could anyone offer any pearls of wisdom or correct these assumptions please?
Thanks in advance for sharing your expertise and wisdom in advance!
Andy (stumped Batman!)
