Kuberg freerider hall sensor problem
3,986
Hall sensors are standard parts, cost pence and you can get them from anywhere.
You can repair that board with UV glue, then scrape off the green stuff from the tracks either side of the break and solder wires to then.
You can fix anything with this glue.
Hall sensors. there can be minor differences between them. Read the designation of yours and post it here so that we can advise you which exact ones to get:
Lukkyg82
May 22, 2021
Thanks for replies I will try and fix with that uv glue will save myself a lot of money if it works as I was thinking it would need a anew motor.
3,986
To use the glue, push and hold the two ends together, then drizzle some of the glue over the joint. Activate it with the UV torch. Turn it over and do the same on the other side. Maybe then add a second layer to each side for extra strength. This stuff is like very hard and strong plastic. Applying it is a bit like a welding process.
