LcD Display
8,755
My default LCD for any KT controller is LCD3.
Reactions: Garry Hallam
Cadence
313
232
There is a thread here that I started about the new KT-TF01:-
I also have the LCD3, and they are both very good.
If buying now I'd be tempted by the KT-LCD8H. Expensive, but combines the full colour screen, easy settings interface and the glove-friendly buttons.
8,755
8,755
LCD3 is pretty much the best value LCD in the range imv , the other dearer ones are nice if you want a bit more then mono however they don't make the bike any faster or more powerful.
If one wants a a low key discreet LCD then the LCD4 is the smallest and neatest package.
harrys
394
107
Chicago, USA
I like the LCD3. It's not real expensive, and is easy to read. It is the only one that gives you the temperature inside the case. Easy to read. Conversely, being the biggest one, it's easier tio damage when the bike falls, Think I have broken three,
The LCD7U offers color, but is hard for me to read, Buttons are harder to press too. The LCD9 is similar, but has a built-in throttle.
The LCD1 is a budget item that doesn't allow controller current to be changed. Doesn't show watts.
8,755
I used an LCD1 for five or six years on my old old Norco 700c conversion, though very basic it worked very well, I also had an LCD3 on another bike so if I needed to change any advanced parameters I used the LCD3 to make them .
If one wants a cheap no frills LCD then it is plenty good enough.
Garry Hallam
104
10
Whilst iI am waiting for a LCD3 I tried the Kt controller on a compatable 880 LCD that I ordered as a spare. Got it connected up but the pedal sensor that I ordered which has 12 magnets will not work. I am guessing it is incompattable because it will not drive the motor. The 6 km speed button drives the motor ok so I guess the controller is good. It seems I need 8 or 10 magnet sensor to work with the 880?
3,898
You need to do all the settings to get the pedal sensor to work. It shouldn't be a compatibility issue.
3,898
In that case this lcd is not compattable. There are no settings
LCD3 is compatible with any KT controller and can do all the settings. The pedal sensor will work with the 880 after you've done the settings. There's a procedure for copying the settings into the 880 that you can find on the KT website.
thelarkbox
1,590
490
oxon
just include '.pdf' in your search string looking for manuals for kt lcd displays, it should result in a page count displa in the search results for easy selection of the largest that will incude the chapter/appendix relating to settings transfer and the cable required,
Garry Hallam
104
10
It was the LCD4 that I ordered. It arrived today. Pedal sensor will still not work. I went through instructions and after setting top speed, wheel size, mph/kh you are supposed to hold down button to get to p settings. Pressing down does nothing?
thelarkbox
1,590
490
oxon
Page 19 of the manual describes how to 'continue' into setting the P parameters.
If you pressed the power switch to save the previous settings and exited you need to start the settings cycle again.
Garry Hallam
104
10
Think i figured it out. Altered some settings. I have the pedal sensor working intermittantly. Think i need a reset and count the magnets in the motor like saneagle suggested
