Lifepo4
aaannndddyyy
304
9
Norwich Norfolk
Hi see there are Li Iron Phosphate (lifepo4) 36volt 10amp batteries on EBay for around 250 pounds with charger plus delivery.
eBay UK Shop - PingBattery: 36V LiFePO4 Batteries, 48V 24V Battery, Electric Bike Scooter
OR HERE (Cheaper)
PingBattery LiFePO4 Battery packs for Electric Bicycle e-Bike & Scooter, Lithium Iron Phosphate Battery
that’s in the same price bracket as NiMh and li-ion manganese:) . lithium iron phosphate (LiFePO4) batteries, or nano lithium-ion batteries as they are sometimes called, are the newest generation of rechargeable batteries on the market.
There are three types of lithium ion cells based on different cathode materials. They are lithium cobalt oxide, lithium manganese oxide and lithium iron phosphate types. Although lithium cobalt oxide cell has the advantage of high energy density, it suffers from safety concerns. Lithium manganese oxide cell has been evaluated for the application on high rate due to the better safety characteristics. However, its high temperature performance is the major drawback and experience from a lot of members on this forum a short life cycle. While Lithium iron phosphate cell has the best safety characteristics, long cycle life (up to 2000 cycles). It is very suitable for high discharge rate occasions such as EV.
30,348
I'm still a bit nervous about LiFePO4 though, since the bike manufacturers seem very slow in introducing them.
eZee have been trying them out for well over a year now, but still nothing arriving as yet, nor from any other major manufacturer, so I deduce that something isn't quite right yet, since the advantages are overwhelming otherwise as you've said aaannndddyyy.
Only the small Sunrunner outfit has them on bikes so far in the UK, and then only in a tiny size with a low powered motor.
HarryB
1,317
London
Do you think it is to do with finding a supplier or even that they have stocks of the LiMn-ion batteries (or tied into a contract to buy them)? Could be a number of things I suppose. I notice doing a websearch on LiFePO4 comes up with a number of suppliers for batteries specifically for ebikes (from the USA) and six months ago there were none. Perhaps they are just taking off. I suppose there are those like me who need a new battery now and are fed up with the LiMn batteries but don't want to go out and buy a NiMH only to find that technology moves on in a few months. Sorry maybe this thread shouldn't be in the FAQ section as it seems a good topic for general discussion.
Ian
1,333
Leicester LE4, UK.
It's rather square shape would not fit the Ezee battery case whose internal width is 64mm. And I guess Its smallest dimension of 95mm would be too wide for virtually all behind the seat tube mounts. A pity as otherwise it would be worth a gamble.
Also don't forget import duty and VAT will have to be paid by the purchaser, and I think as the only shipping service offered is UPS expediated there will be no escaping these costs, the consignee being invoiced by UPS before delivery.
HarryB
1,317
London
Ian,
They do a version that is 350x85x65mm so I suppose it is not impossible to get one to fit. You are right though the import duty and VAT make it questionable adding about £52 I think.
Ian
1,333
Leicester LE4, UK.
Harry, by a strange coincidence (Or design?) that is almost the exact size required for the Ezee case, and possibly others too. Perhaps if these batteries begin to catch on competition will force prices down. I would be very interested to learn how they perform in the real world.
aaannndddyyy
304
9
Norwich Norfolk
All though this item has finished it dose give a picture of the battery with the dimensions Ian mentioned that will probably fit in the ezee case EBay no 270159880567
type; LiFePO4 E-bike pack
Volt; 36V
Capacity: 10Ah
Dimension: 350x85x65mm(Small in Size)
Weight: 6KG
This LifePO4 unit including the LiFePO4 pack, BMS(battery management system) and a 3A charger.
[/URL][/IMG]
coops
1,225
Manchester U.K.
I may be wrong, but I get the impression (from some posts on endless-sphere) that, although the A123 'nano-phosphate' and other iron phosphate (LiFePO4) types share a similar name & iron cathode chemistry, there are structural differences between them which might result in differing performance (e.g. current supply or 'C' rating) & lifetime: maybe this partly explains the inconclusive trials?
The A123's are not commercially available, as far as I know, except by dissecting powertools etc. batteries.
At 6kg (does that include charger too, perhaps?) the 36V 10Ah LiFePO4 battery weighs more than a 9Ah NiMH? Higher cost, weight & uncertain performance and
lifetime would make it a non-starter for me. A single, taller and higher capacity battery to fit Ezee bikes would be good, but thats a tall order I guess :rolleyes: :).
Stuart.
30,348
I suspect that it is price that's holding back their introduction, they are expensive,
It's certainly not existing Li-ion stocks, since these are made just to match demand due to their self ageing characteristics, hence them intermittently not being available.
If there's no progress in us getting these for our bikes by the Spring, I'll happily buy one of these inserts and try it, but i won't bother in winter cycling conditions. Masochism isn't one of my strong points!
coops
1,225
Manchester U.K.
Just came across a long thread on Yesa LiFePO4 batteries, the same make as those on ebay.
Haven't read it fully yet, just sharing the information :).
A 24V 10Ah is 230 x 85 x 65mm and weighs 3kg, so the 36V 10Ah 'Ezee size' one should be around 4.5kg? 3A Charger weighs about 500g.
Also, this is from the Yesa ebay Q&A:
Q: how much for a 48v battery and charger. thanks. 01-Sep-07
A: 48V 10AH LiMn2O4 , USD500, 48V 15AH LiMn2O4 USD540. 48V 15AH LIFePO4 USD680, we do suggest people choose LiMn2O4 pack when under 15AH. Cheaper but also good as LiFePO4. LiMn2O4 is not suitable for pack above 15AH .
and
the LiFePo4 battery is newly developed project in our company , we are trying to develop some more yet.
30,348
That doesn't sound good when a manufacturer of lithium iron phosphate recommends stick with Li-ion manganese under 15 Ah.
And as they say they're just as good, does that mean LiFePO4 are just as bad (same thing) and also cut out due to poor current delivery?
Makes one wonder.
coops
1,225
Manchester U.K.
I should have added the other part of the Q&A, for completeness:
Q: hi whats the diference between limn204 and lifepo4 thanx 01-Sep-07
A: In Generally , LiFePO4 is better but more expansive than LiMn2O4. LiFePo4 cell is 3.2V , LiMn2O4 is 3.7V . And LiMn2O4 can only be made for Pack under 15AH yet. But LiFePo4 has no limit.
So it sounds like they're saying LiFe is better, but not so much better its worth spending more for than LiMn, for 15Ah or less...?
The ebay page also says 70% of the weight of NiMH, which I don't see as correct if 36V 10Ah weighs 4.5kg?
HarryB
1,317
London
Ian,
Having checked out the ezee case I don't think the 350mm battery will fit anyway. Does anybody have the internal dimensions of the ezee case?
coops
1,225
Manchester U.K.
I don't Harry, though someone who has opened their case may know :).
To be honest though, I can't see that performance would be (much) different from the existing Li ezee batteries, and at 4.5kg its quite heavy and not as cost-effective or reliable as NiMH, which weighs only fractionally more.
Another quote from the manufacturer in an email reply to an enquiry about discharge rate and voltage sag for a 24V 10Ah battery:
The 10AH pack for your 250W motor is enough.
The standard discharge rate is 1C = 10A
You test 22.5V at 15A is normal.
But we do not suggest to have too high rate discharge , since that may reduce the lifecycles.
We can make 12V pack, but 12V pack is not so popular , we have 24V, 36V, 48V pack .
The capacity can be 10AH , 12AH, 20AH .
So its a battery rated for low power use: 'standard' discharge meets less than 2/3 of e.g. a Torq's peak power output, and only half that for an f-series bike.
I wonder if other LiFe batteries are any better (why does it seem that powertools use decent quality Lithium batteries, but they're not available for ebikes??), but at the sorts of prices & weights these ones are, it just really doesn't seem worth paying any more for them than NiMH, especially given the uncertainty about performance & lifetime.
30,348
I think it's mainly price Stuart. Although iron is the theoretically best cathode material of all the elements, it's proved very difficult to construct a reliable high current delivery example.
Hence it mainly appearing in small moderate current delivery batteries, the Sunrunner low powered bike being a good example. I think it will be some while before they are good enough for the more powerful e-bike motors within a useful weight and size.
Where performance of lithium batteries is concerned, cobalt gives the best delivery and capacity combination, also much better than manganese, just a pity about the fire risks that come with low manufacturing standards.
Jeremy
1,010
Salisbury
The "Killacycle" electric bike has been running A123 (M1) cells (which are the LiFePO4 ones in DeWalt power tool packs) for some time now, at very, very high discharge rates and is reputed to have not yet blown a single cell.
Last time I checked Killacycle was drawing around 1800 A at about 370V from about 1200 cells (I think they've since added more cells to increase this a bit, in order to hit sub-8 sec standing quarters). Some simple math seems to show that this bike is drawing about 180A (peak) from each cell, so it's clear that these cells do have a pretty good high current capacity (although obviously their capacity will be significantly hit by such high discharge rates).
The major problem seems to be one of supply. A123 do not sell cells, as I understand it, to anyone except a select group of big companies (like DeWalt). The result is that smaller companies, such as those in the ebike world, can't get a look in. Those that do sell A123 packs are apparently ripping them from cordless tool packs, which is not exactly cost effective.
I've no doubt that the Chinese will soon be producing cloned cells that are reliable, but at the moment there does seem to be a big question mark over the quality of some cells/packs sold via Ebay and the like.
I'm running a small SLA pack at the moment, and was thinking about buying some NiMH cells and making a replacement. Having looked into various cell types in depth over the past couple of weeks I'm very much inclined to try and get hold of some LiFePO4 cells of decent quality, as all the indications are that this technology has the best mix of life, capacity and weight at the moment.
One our research programmes has been running extended life tests on several different Li technologies and this also tends to show that LiFePO4 may well be the best available technology at the moment.
Jeremy
Ian
1,333
Leicester LE4, UK.
You are right Harry, the 350mm height will not fit. The Ezee case will just take a 5 high stack of D cells, approx 310mm, there is slightly more height at reduced width but a full 350mm is only available over an area of about 50 x 50, and only then if the XLR connector and fuseholder are removed. So unless the cell pack has an offset conical top ti will not fit. Seems I was over optimistic with my earlier hasty measurement.
A Flecc style extension to the case could always be made, but given the high cost and 6kg weight is it worth it.
30,348
There's no doubting the potential of lithium iron as Jeremy has said, but it's only available at an unacceptable cost to most at the moment.
The main concern I have with using continuous high discharges on them is how that will affect their life, even a three year life at those high prices being inadequate.
For me the best all round option when cost is factored in is still NiMh, even after their recent price increases. Once good ones are cheap enough, I'll switch to LiFePO4 instantly.
