Hi, I'm replacing the battery on my Pulse Ebike with a chinese battery, but the battery has arrived almost fully charged (37volts) with no way to switch it off. As the red wire is live, how do I safely couple it to my controller? Do I have to discharge the battery ? If so, how do I do that safely? (not too hot with electrics)
I also see that the battery charger cable that comes with the battery has a standard negative/positive push in end that plugs into the battery, rather than a 5 pin push in end. Does this mean that there is no protection inside the battery pack? Thanks for any help, Norrie.
