Looking for advice on 48v battery
Michael 2025
30
44
Hi guys a eventually went with mid drive motor tsdz8 750 w now am looking for 48 v battery to pair up with
been looking at Greenlance as it’s been recommended by few ppl on here
but don’t know what ah to get 13/17 /20 ah
Looking get 30 miles use assist on level 3
but don’t want get to big be over kill as be charge it at work when get there that’s
11 miles
green lance says there battery can be charged 1500 times that’s make me suspicious max is 500/ to 1000 max
3,977
11 miles
I'd get the 20ah one. Not only is it guaranteed to do your journey, but it'll get an easier time doing it, so it'll last longer. Plus, you might want to use your bike to go a lot further.
Michael 2025
30
44
A can’t seem to work if it would just screw the new bracket from Greenlance , why have there change them to 2 slots instead 3or 4 ??
Sparksandbangs
121
39
The 2 slots on the greenlance holder can fit mounts between 5 and 8 cm apart.
The holder has an enclosure for a controller at the bottom and the underneath is metal. You can drill through that to get a lower mount if you are not having an integrated controller. I might be able to take a photograph later if no one else can point to one.
3,977
Heavy batteries need at least three fixings, and you might as well do 4 while you have your tools out. It's not difficult to add a couple more rivnuts. All you do is:
  • Mark the centre of the two empty slots
  • Remove the mounting plate
  • Centre punch the two marks
  • Drill the holes to suit the rivnuts in several stages going up in drill size
  • Insert the rivnut and crimp it
  • Check that the screw goes in easy. If not clean the thread very carefully with a tap. The worst thing is if the rivnut starts to spin before fully tightened, as you cannot remove anything stuck in it.
  • Screw down the mounting plate very tight to fully form the crimp.
You can get a rivnut kit on Ebay for not much. The biggest problem is getting your drill at the rightangle to drill the hole. It doesn't matter if you're not quite straight. You might want to think about using one of those angled drill adapters.
drill chuck:
Angle adapter
Michael 2025
30
44
Thanks for a think a will give this ago ,
Just need make sure drill the right size holes , could you tell me if Greenlance are use legitimate Samsung sell , not much about them on the internet ,
3,977
I didn't open mine. I have two and they've been working fine for a year already.
Michael 2025
30
44
Guys been looking at this battery to as well as green lance
this battery weight 6kg. Does this not seem a bit
Strange for small ah
a work out 39 cell at 69g only 2.6 kg
How does work out 6kg ???
Even some off the big battery only weight 5kg
matthewslack
2,492
1,630
Maybe the 6kg is gross weight of the box, including charger, mount and the box itself. Ask the company, they must know. If they don't answer, or if they don't know, don't use them.
3,977
What one did you get , and roughy how many full charge you done is well over 100 and has the battery lost some off the range ,
Those two are both 20Ah. One has 18650s and the other 21700s. I can't see much difference in performance, but I only ride with lowish power. I've no idea how many charges because I have 4 batteries on three bikes and I keep swapping them around. The first one I got from Greenlance was used the most on my main bike. I don't even know which one of the 4 it is now. I never measure range because I don't empty them on a ride.
Michael 2025
30
44
Are these the right measurements for the Greenlance 48v 20ah or 110mm Just conflict reports. That it’s 127 mm hight could you double check as you have this battery please
3,977
I'll check later, but you know you need extra clearance to fit the battery to the holder? You need about 20mm above and at the front, plus the height of the battery at the bottom end interferes with the seat tube, so the whole battery is prevented from going too low on the downtube.. it's best to make a cardboard model to check fitting if it's tight.
3,977
Those dimensions look right as far as I can measure with a 12" ruler.
David989
13
Hello Guys,
I've bought a conversion kit and Battery from Greenlance.
48V 1500W motor with 48V 25AH battery. It was quite expensive but the Samsung cells and 2 year warranty pushed me into buying, lol.
I have also purchased the remote speed restriction with the kit.
The motor is quite big on the back wheel. I wanted to use it on the streets at 250W. Has anyone got issues with the police, even when the speed is restricted?
Sparksandbangs
121
39
Hello Guys,
1500W is illegal in a public place and nothing says 'stop me and buy one' more than bolting a dinner plate to your back wheel.
Reactions: Cyclist
