Minimum stem engagement on alloy steerer?
cycling weakly
93
21
77
I know that it is recommended to have the top of the steerer tube about 5mm below the top of the stem, but I have just swapped a fork from another bike & the best I can get is 13mm. This leaves 27mm of the steerer gripped by the stem. Any thoughts on the safety or otherwise of this setup?.
Steve
Can't you get a narrower stem? 40 mm seems pretty high. I have some around 30mm.
  • Useful
Reactions: LeighPing
cycling weakly
93
21
77
Hi Dave. Do you know what make & model the 30mm high stems are?. I have done the rounds of the lbs's & the only stem under 40mm I came across was a Deda Newton lightweight road stem which was 37mm tall & too frail looking for offroad.
Steve
6,316
cycling weakly
93
21
77
Thanks for that SW. I am now mulling over buying a used Fox Float 100mm fork with a longer steerer, for £150. Or putting the BBS02 into a Whyte 605 that is gathering dust in my kitchen. My indecision is final!.
Steve.
