I have been told it is possible to do the above using schlotty diodes to prevent one pack 'back bleeding' into the other. I can see it working with two packs of the same Ah & cell type. Otherwise I think the pack with the lowest internal res would tend to discharge first, but also one pack having a greater HVC than the other would have a bearing. I am asking if 10 Ah lipo4 could work with 8 Ah Li - ion (Panasonic 18650PF cells). At present each pack would run its own motor (two motors on the bike) I fear the Tonxgin one day giving up & having to go to a single Q128H (poss to replace the Tonxgin with another small front motor) - but there are weight & cost advantages in eventually going to a single motor
It comes down to weather to build a 3P or 4P pack from the 18650 cells. The 4P pack would cost more but would be 'future proof' Both packs are Nominal 36V (actually 43.8V & 44.2V) Reason for going to 18650's is affordable availability in Europe, so cheap surface shipping.
