Mosfet question
PastyMan
44
Truro, Cornwall
Checking them on my eZee conversion controller I got the following values in k ohms.
GreenYellowBlue
+1207050
_906030
Looking at stuff on the web suggests they should lie in a similar range of values.
Do these values suggest anything abnormal?
8,225
Depends how one is testing them and if the testing process is correct.
PastyMan
44
Truro, Cornwall
Controller disconnected from battery, and motor.
Multimeter set to 200kohms.
Readings taken between the negative anderson battery connection and each of the three phase wire pins on their connector, then repeated using the positive anderson connection.
8,225
The readings are very different and certainly not in the range one would expect.
Has the controller failed ?
