Recently on a 20 mile ride the motor cut out about 5 times but restarted if I switch the 'ignition' key on and off.
Checked for loose connections etc and found one I suspected might be dodgy. Soldered, reassembled but same fault.
Thinking maybe a faulty 'ignition switch' I bridged the switch, tried this morning, failed after 2 miles and wouldn't restart at all.
The electrics are an Alien Ocean front wheel conversion kit about 5 years old. Only an on/off switch and the throttle are connected, no pedelecs, no brake lever cut offs - nothing.
The battery was upgraded to 36v 15Ah by Jimmy at BGA in Nov. 2016. Fully charged it puts out 41.2
It's this type of battery although I suspect it's irrelevant
Any ideas, suggestions, help, gratefully received.
Dawes 700
Dawes 700
