Hi David/Doug
I've got another problem I'm afraid... My bike (905se Sport) has been acting very strangely today. I last rode it on Wednesday, and it was fine. However, the following has happened today:
When I first rode the bike this morning, the motor started after a few pedal revolutions as normal - however, it would not stop after this, no matter what I did - stopped pedaling, brakes, no throttle - the wheel still wanted to spin (and shoot me over the giveway into the main road, incidentally). The only way I could get the motor to stop was by hitting the main red power switch.
The problem then developed half-way through my journey, so that the motor refused to start at all, even when I started pedaling. This time, I found that toggling the green derestrict button caused the motor to activate again, and then I was in the same situation as before - the motor would not stop after that unless I turned off the main power.
I have just got to work, and did a bit more testing to help diagnose the problem, with the bike on the stand, back wheel lifted just off the floor. Starting with all power turned off...
Turn power on - motor is off, as it should be.
Twist throttle - nothing happens - motor should have activated.
Turn pedals a few revolutions - still no motor.
Toggle green derestrict button - wheel starts spinning, won't stop.
Depress right (front) brake lever - motor cuts out, back wheel slows down.
Release right brake lever - motor reactivates.
Depress left (back) brake lever - motor cuts out, back wheel stops.
Release left brake lever - motor reactivates.
(This is all with no pedalling, and no throttle).
I also found that if I fiddle a bit with the cables around the throttle area, sometimes the wheel will suddenly start spinning. This is all a bit dangerous, as it is a little unpredictable...
Do you have any ideas of what I can look at/check to fix the problem? The only thing I have done recently is change the handlebar stem (on Friday), and I removed the left brake & derestrict button to do this, so I could thread the handlebar through the loop on the stem. Is it possible I've desturbed any wiring by doing this that would cause the symptoms listed above?
Thanks,
Howard
Thanks,
Howard
