In view of the Torq's (hopefully temporary) return to Loughborough last week, I was delighted to get the call from Tony Castles to say that my nano kit was ready for collection. I picked it up from Tony and Simon Mills (both delightfully enthusiastic and helpful) at the beginning of the week and immediately set about the donor Brompton (silver 3L).
Installation is reasonably straightforward (needs to be for me) and much as described in the atob article. A few trips to the computer to look at the pdf and a brief panic when I reversed the polarity on the battery-motor connection. Then a quick trip to the local bike shop to tighten up the steering and I was away. The bike works in ebike mode, so with a twist of the throttle, you're away even without pedalling. The kit is nicely put together although there are obviously a few bits that will be a bit vulnerable when folding and I'll need to watch.
So far, I've only been a few miles. Performance is, frankly, pretty amazing. The heavier front wheel is barely noticeable and the bike retains the handling characteristics of the Brompton. It accelerates quickly and zips up hills (say, 1 in 8) without pedalling. As expected, its far better in this regard than the Torq, although it obviously doesn't have the out and out speed of the Torq in derestricted mode (not sure I'd want that speed on a Brompton). The motor seems to be completely silent most of the time. One of the really nice things is having the underlying familiarity of the Brompton. It folds well - its a bit wider due to the widened forks/motor. Folded, the handlebars have a bit more of the tendency to swing out - so I add a small elastic restraint.
I'll put in a few more miles and report back. But, so far, excellent
Manchego
Manchego
