For Lithium Batteries, whats the best way to charge them from new? Should they be completely run down and recharged, or should they not. Some instructions are very confusing?
John
John
You're confused!For Lithium Batteries, whats the best way to charge them from new? Should they be completely run down and recharged, or should they not. Some instructions are very confusing?
John
Project J?Ian said:John, I'm curious why you're asking about Torq batteries, I thought you were a Giant owner, is there something you've not been telling us.
So what may we take the range of a Lithium Battery to be from full to empty?John, unlike NiMh, lithium batteries should not be completely discharged if it's avoidable. Topping up at every opportunity will help to maximise the life of the battery.
That's around the expected area Peter. Typically with normal use lithiums will lose around 35% capacity per year of the capacity at the start of each year.My first Deep Discharge of the battery on a Torq was 30 miles to "Dead Flat".
After that, one should, I suppose, restrict the use to 80% of capacity. That's 24 miles and after a year's use, probably only 80% of that, 19 miles. That's where I am at this time - 18 miles after 11 months.
Peter
its delimited, and test ride pendingSo are you going to show him where the delimiter is & volunteer to test it first John? .
"The 80% discharge you mention is technically far from ideal......."That's around the expected area Peter. Typically with normal use lithiums will lose around 35% capacity per year of the capacity at the start of each year.
If one is not ideally used by deeply discharging it all the time, the capacity loss can rise to as much as 66% each year.
The 80% discharge you mention is technically far from ideal, these batteries are best used at only about 20% of capacity or less each time before charging, but that's impractical of course. Just one of several reasons why some of us persist with NiMh, despite the nuisance of needing to do quite full discharges from time to time.
That's the point Ian, it ain't bigger!I share your view of lithium batteries Peter, whats the point in having a bigger battery when it soon gets smaller and your not supposed to use it all anyway.
The problem is that NiMh batteries are in short supply and prices are rising rapidly, of course the industry has turned the situation to their advantage by supplying lithium and promoting it as new technology, which you can't really blame them for as the alternative would be to say "sorry guys, no more NiMh so you've got to have lithium, it may not last long and it's more expensive". To put it like that clearly is not good business.
