Newbie
Justingrimsby
7
Hi everyone
Don’t hardly no much about ebikes
But done the moving sensor on back swinging arm with magnet on the peddle
and keep getting error and no power now and then
Will it damage my bike
MontyPAS
390
148
Anyone no anything about this
Or do I have to buy some thing
Bit more info might help. What bike/motor etc?
Why are you moving magnet onto pedal, where was it before rear wheel?
Justingrimsby
7
mots a Bosch motor performance line cx
The magnet is on the back wheel
So I’ve placed one on the back of the peddle
Then moved the little senor on the back swinging arm so the magnet on the peddle passes it rather than the one on the wheel
But twice now I’ve had an error displayed and no power
1st time it come straight back on
2nd time took 10 mins to come back on
MontyPAS
390
148
Not got a Bosch, but the magnet/sensor was set to measure the rotation of a set circumference wheel, being on the swing arm & wheel
Now you are trying to measure crank rotations, which vary by gear selected. CPU probably throwing a wobbly??
Gavin
316
179
I take it you've moved the sensor in the hope of removing the speed limit by "tricking" the system into thinking the wheel is revolving slower?
If so, then the system may well be smarter than you think and by altering one parameter (wheel rpm) you've created a conflict with another.
Another possibility is that you've got the magnet too close/ too far from the sensor.
Use the search function on the forum, I'm pretty sure this has been discussed before...
Reactions: MontyPAS
Wicky
2,823
4,011
Colchester, Essex
www.jhepburn.co.uk
The software of the Bosch eBike systems can detect whether the pedelec has been tuned by means of a sensor while riding. It then switches to emergency mode. Consequence: an error code in the display indicates manipulation and support is reduced. The eBiker can restore the original riding settings by riding the pedelec for around 90 minutes. As soon as the system returns to normal mode, however, the manipulation check will be repeated. After the third time, limp home mode can only be deactivated by a specialist dealer using the Bosch DiagnosticTool.
Justingrimsby
7
yes I was removing the speed restrictions
So wot can I buy to remove the error
8,219
A Bosch diagnostic tool....
After he has bought one, he can then set himself up in business to deal with all the tampered bosch bikes :rolleyes:.
8,219
You have to go on the Bosch course and register as a dealer before they will sell you one.
Yes I knew that vfr, it was a tongue in cheek reply to Gavin's response hence the emoji.
Justingrimsby
7
Had my 3rd error today and just thought oh well
I’ll have to get home so carried on riding
After ten mins it resets its self
So happy days
