B billym1967 Esteemed Pedelecer Apr 13, 2017 316 27 58 durham uk Mar 26, 2018 #1 has anyone got one. ive tried and searched and can not figure out how to use the discharge mode on it. anyone no how thanks
soundwave Esteemed Pedelecer May 23, 2015 17,887 6,722 Mar 26, 2018 #2 i have a d2 but there is no discharge option on it. and cant see one on the d4 either. http://charger.nitecore.com/CHARGER/D/D4/ what you want is a imax charger to discharge cells to get the mah. https://hobbyking.com/en_us/imax-b6-dc-charger-5a-50w-copy.html?countrycode=GB&gclid=Cj0KCQjwtOLVBRCZARIsADPLtJ2OfganLlYI2eHCuM0lDPnr9q2ekiVSMlQZe2r7K0VgCm1amSm_kN8aArmaEALw_wcB&gclsrc=aw.ds&___store=en_us
B billym1967 Esteemed Pedelecer Apr 13, 2017 316 27 58 durham uk Mar 26, 2018 #3 my fault half a sleep when i ordered, thought it said discharge on the box and its digicharge lol
soundwave Esteemed Pedelecer May 23, 2015 17,887 6,722 Mar 26, 2018 #4 a imax is what you want and a cell holder. https://www.ebay.co.uk/itm/XD-3-1-2-3-4x-Li-ion-Lithium-18650-Battery-Box-Holder-Case-3-7V-Pin-Pole-Sold/142131077352?ssPageName=STRK:MEBIDX:IT&var=441208306869&_trksid=p2060353.m1438.l2649
B billym1967 Esteemed Pedelecer Apr 13, 2017 316 27 58 durham uk Mar 26, 2018 #5 yes got one, can you discharge several cells at once. on the imax
soundwave Esteemed Pedelecer May 23, 2015 17,887 6,722 Mar 26, 2018 #6 you could if you use the cell holders but it will discharge as one big batt so if you want to get the mah of each cell then best to do one at a time. it will only discharge at 1amp tho so if you have 4 like above it will take 4 times as long.
