My friend took his Decathlon front hub bike for a short ride in the rain. It developed a lot of noise which he tried to stop by filling the motor with WD40...
At this stage I come into the picture.
I did a short test ride and effectively the motor was much noisier than when I picked it up at the supermarket. Yesterday I opened it. The grease is black as tar which not surprising even though this is a very low km bike because of the WD40 that was injected into the motor. There are no obvious mechanical problems.
1. Could water in the electrics be the cause for this rough running? I did try it quite a long time after he initially had the problem so it should have evaporated.
If anyone has any paths to go down I am open to suggestions. First of all plan is to clean out the factory grease, re-grease, assemble and retest.
2. what grease do you recommend?
Cheers
Cheers
