Octalink PAS recommendations
+40 Joe
Jun 28, 2025
Hello Everyone,
My neighbour has asked me to switch a generic e-bike kit from his old bike to his new bike, no problem i said, all looks straight forward!
The issue big his old bike had a square type crank with a left side PAS, his new bike has a shimano octalink type crank (22mm OD shaft).
I've searched the web and keep ending up at this one:
Octalink cadence sensor set | ebike-solutions.com
Anyone know if there is an option that i could purchase from the UK? I found a few links in this forum but they no longer work!
8,769
Search for KT BZ10c on ebay or Amazon , they are circa 10 - 12 quid. If buying the moulded connector model then one may not have the correct wire sequence compatibilty so if it still doesn't work simply cut off both connectors and join the wires correctly .
