Oxygen S-Cross CB battery upgrade
rexel1
9
49
North East London
Hi,
I’ve got an Oxygen S-Cross with the upgraded battery (13ah). I’m normally using the full power mode on my commute.
Unfortunately I’m moving offices soon and the daily commute will increase by a few miles to around 30 in total. I don’t really fancy charging it up at work and then at home each day, so I’m wondering if anywhere sells a battery that will fit and work with the bike.
I know it uses the reention battery type, but would I need a new controller etc or could I find a larger battery that will work? I know whoosh bikes do a larger size battery that would fit physically.
As long as the battery tits in the receiver and has the same nominal voltage (36v), it,all be OK.
Reactions: rexel1
