Oxygen s cross mkll LCD?
Underlayunderlay
37
Dorset
Hi, I'm new on here and also a new Oxygen owner.
I've so far managed to set up a throttle using the select + buttons bit only get 21.8mph. Has anyone achieved a higher mph?
My main reason for posting is that I cannot get back into the menu for wheel size, mode etc and forgot which buttons need pressing and in which order?
Any advice appreciated.
C.
Reactions: KirstinS
Underlayunderlay
37
Dorset
The speed has a different limit for each level in the LCD. Did you try it on the highest one? Is your 21.8 mph with the wheel off the ground?
Yes vfr400 (btw do you still have that amazing bike?) I've had it hanging from a bike repair stand. It also does exactly the same (21mph) when all 16 stone of me is on it! It also makes little difference which level mode I'm in.
At the moment I have it in Power mode, level 6 and wheel size 26inch. The throttle pick up is slow to start off but great when it's up and running over 7mph.
It also wont go up steepish hills without some help, in any mode, I put this down to the lump on board steering it.
Thanks for the advise so far,
C.
