Paintwork protection ?
pichipedals
44
13
56
I'll be protecting vulnerable areas of the frame with paint protection film, but wondering what to apply to the rest - i've got ceramic coatings on one of my cars (Gtechniq) and expensive carnauba wax on the other. Both work well but that latter needs more upkeep and is less dirt repellent in general.
What are people using to keep road grime at bay, or at least to make washing / upkeep easier ?
egroover
976
578
56
UK
I use MUD.
Once applied it forms a protective coating, which improves over the course of the winter . Come springtime I just remove with water and hey presto! lovely paintwork and no rust
2,674
I use MUD.
You've just reminded me; I did mean to clean off last winter's mud in spring. I guess it's a bit late now.
Reactions: egroover
pichipedals
44
13
56
I’ve heard of ACF50 but I’d it a dry film once applied and will it rub of on contact areas like the top tube and cranks ?
Gavin
316
179
It's an oil-based corrosion inhibitor. Dirt sticks to it and it makes a right old mess- probably not quite what you're after!
Atlav4
179
75
Electricians tape wound as neatly as possible on anywhere that may rub scrape or scuff. Easy on a black frame but tape comes in a variety of colours just match as close as possible.
3,986
Reactions: Nealh and MontyPAS
MontyPAS
390
148
Gavin
316
179
I've been putting this stuff on my beaten up old frame. After 6 years, it now looks like new:
It says it protects from precipitation- I wonder if it helps you ride your bike in the rain....
Reactions: MontyPAS
pichipedals
44
13
56
Well I might live in a rural area but theres Not a lot of mud on the roads so that option is out.
wont be putting helicopter tape or PPF all over the frame either, just areas of cable rubbing and stone / debris vulnerability.
looks like the rest of the frame and wheel rims will be ceramic coated then.
thanks
Peddlin' Pedro
144
65
West Sussex, UK
I use MUD.
Absorbs radar too if distributed properly. Perfect if you're running on the naughty side the pedelec regs, so I'm told
2,674
I'm confused there. Have you been putting it on your own beaten up old frame, or your bike's beaten up old frame?
Pedaluma
30
I use spray on/wipe off car wax as I dry a bike after washing. It leaves a protective film and is quick and easy. I wash bikes outside in a portable bike stand using a spray bottle with some laundry soap and shampoo with water and a touch of fabric softener. I then rinse using a yard sprayer with water. The pressure of a pump up yard sprayer is low enough not to penetrate into bearings. To protect the tires from dirt, I use a bit of DOT 5 in a spray bottle with a dash of dish soap and mostly water. This also makes them look new and works great on plastic such as battery covers and cable housings.
Reactions: pichipedals
MontyPAS
390
148
