Pedelec noises
Scancrow
Hello everybody,I'm new to this forum, I'm looking for help regarding my pedelec.
Since some time it makes these noises at the engine area, they usually happen when I'm starting from a stop or a traffic light, at the beginning I thought the noises were from the cassette cause a friend of mine with the same bike told me it's that problem cause he had it too and he fixed it with a new cassette, but after replacing my cassette with a new one the problem still persists and I could bring it to the repair but I'm the kind of person that likes to do things alone cause I'm interested in it.
Im gonna try to describe the problem in more details and also gonna link a quick clip.
So the noises as a said happens just when I start after a stop especially at traffic light and it doesn't matter if I'm sit or standing(happens with the same frequency), it's a strong noise that resembles the sound of the chain changing speed but it's not the chain, it definitely comes from inside the box where the engine is, also the speed doesn't matter, although I noticed it happens mostly when I'm going fast.
Clip:
Oh yeah and the model of the pedelec is: Rockrider Est-900 from decathlon with a bride engine.
Deleted member 33385
To me, it sounds like your chain is slipping between gears - adjust the:
Scancrow
I thought about that too, but it's not, it's coming from the engine compartment under my feet and not the rear gears
If when you adjust the cable tensioner on the gear changer, the occurances of the sound changes - I'd say it's likely caused by your chain slipping. It might not be something you can see when you're running through the gears - could just happen under load ie when riding from a dead stop or attempting to go fast.
6,319
sounds like a broken gear inside the motor but does it have a brose motor?
Scancrow
then i will try to adjust that and then we will see, although i doubt that is the problem since i can feel its coming from the engine
6,319
right do not ride it anymore as will do even more damage out of all the motors theses are the worst to work on and you cant buy any parts so peter is your best option to have it repaired.
it could need a new belt but you can remove the side cover and have a look first b4 you send it to peter worst case.
Whoa - It'd be better if it was just a case of a stretched chain, and it slipping. That looks expensive.
6,319
there is a bolt on the motor for belt tension it could be a bit loose so try that first ;)
Scancrow
How do i do that? i will try that otherwise i will bring it to the shop and hope that they will not make me pay since i have warranty, i was trying to avoid that since i suspect they can say it damaged itself and it isnt covered in warranty
Scancrow
anyway thank you guys for the quick responses, i have cleared my mind a bit, i was thinking about this all the day xD
6,319
if it has warranty then take it to the shop all they can do is adjust that bolt anything else then it will need a new motor as dealers can not open up any motors under warranty.
