Pendleton eSomerby Controller Upgrade
Bikes4two
1,036
445
Havant
Thanks to @Seajay in this post here for initially raising the topic and others such as @Nealh for the suggested kit list and for tips on setting up parameter ‘P1’ (more on that later) by @DuncanDK in his posting here.
Why Change The Controller?
The Pendleton is the first ebike in our household and this 2017 rear hub motor model was bought for my wife a few weeks back. Right from the start, she couldn’t get the hang of the powered side of things, experiencing difficulty in keeping a steady pace alongside other riders and just seemed to accelerate to a set speed and then cut power.
I gave it a spin and after reading about such things in this forum, realised that the method of control is speed control rather than torque control which accounted for the phenomenon of the bike accelerating to a set speed before cutting power (about 6.5mph in power assist level one, 11.5mph in level two and 15.5mph in level three).
An alternative controller that offered simulated torque control was suggested in Seajay’s thread and I was happy to follow this advice.
Having now fitted the new controller I can tell you that the ebiking experience has been transformed in that the pedal assistance is smooth at all speeds with the degree of assistance (as in percentage of available power) available in 5 incremental steps. So if this upgrade is of interest to you – read on.
The Kit List
Ordered from Top Bike Kit here on a Monday and delivered by DHL the following Friday. The total cost including a very small Customs charge (see TBK’s FAQ on this topic) was just under £80, £23 of which was for DHL as opposed to something like £12 for China Post which would have taken a few weeks to arrive.
The Kit
  • T-06S 24V/36V250W Torque Simulation Sine Wave with Julei Waterproof Connector (T06S controller Waterproof Plug)
  • Cable – 1-4 Cable
  • Display - KT LCD5
  • 9Pins - Without cable
  • Brake – Without brake
  • Throttle - Wuxing 108X Thumb Throttle
  • PAS - Without PAS
NB – most people seem to go for the KT LCD3 display which offers a few extra features but for aesthetic reasons only, I went for the LCD5 as it is much smaller in size and leaves the handlebars clearer for other accessories.
Fitting the Controller
This only requires basic tools such as Philips screwdrivers, Allen keys and other minor items like cable ties and a very moderate technical ability.
Disassembly
  • Slide out the battery from the battery holder
  • Release and cable wrap and ties and unplug the 3 leads going into the bottom of the battery holder (power lead to the motor, the PAS sensor lead and the long lead going to the LED ‘790’ handlebar control).
  • Attach a piece of string to the ‘790’ lead and withdraw it down the seat tube cableway (the other two leads may well come down too, but that’s fine). The string is to make it easy for when the new controller lead is pulled back up the cableway.
  • Detach the ‘790’ lead from the clips on the underside of the down tube – this can be done by prising open the clips with a pointed tool – don’t worry about damaging them as they can’t be re-used as the replacement lead is fatter than the ‘790’ lead and the clips won’t fit.
  • Unplug the ‘790’ lead from the front brake sensor leads and the handlebar LED display and remove the latter.
  • Next, the battery holder – first, release the 4 Allen bolts holding the pannier rack to the bike. Then turn the rack upside down to access the 4 screws holding the battery holder to the pannier rack.
  • The ‘790’ controller is located in the front part of the battery holder and is accessed by removing 4 small Philips screw on the underside. Once released, the ‘790’ controller can be pulled free.
The Controller and Electrical Connection
  • At this point you will notice that the black and red leads on the new controller have ‘bullet connectors’ whereas the original ‘790’ controller has a plug and socket arrangement.
  • There are a number of different ways in adapting this connection and will depend largely on what connectors you have to hand to make the transition. I had fresh bullet connectors in my tool box so stripped back and ‘tinned’ the wires and crimped them on. In the absence of all else you could get away with using simple ‘choc block’ screw connectors or the like.
  • Do bear in mind that this connection is the one carrying ‘the amps’ to the motor, so it needs to be a good solid connection.
  • You will also note that the new controller has a 2-pin red connector for ‘Light Output’ for which there is no matching connection on the Pendleton. As yet I have not discovered a use for this, so I have capped the end to prevent water ingress and tucked it out of the way.
Reassembly
  • The new controller does fit comfortably and tightly in the battery holder. You will need to fiddle around a bit to find the right orientation of the controller in the holder compartment but it’s easy enough. Take care of course to not put unnecessary strain on the leads as they exit the holder compartment.
  • Attach the new KT-LCD5 display to the handle bars and plug in to the 1-4 cable along with the two brake sensors and the thumb throttle controller.
  • I have chosen to not fit the thumb throttle mainly because its location is too near the derailleur thumb shifters and secondly, my wife doesn’t want it. However, I loosely plugged it in for testing purposes.
  • Run the 1-4 cable back along the down tube and back up the seat tube cableway, using fresh tie-wraps where needed.
  • Re-attach the battery box to the pannier rack and the pannier rack to the bike.
  • Plug in the 1-4 cable, PAS sensor and motor cables into the new controller leads. I did find the 9-pin motor connector required a bit of a push to get it fully homed.
  • Re-insert the battery, switch on the LCD display, raise the rear wheel off the ground and give the throttle a tweak and the motor should turn. If not, there’s something wrong and you’ll need to re-visit the installation.
Setting Up the KT-LCD5
  • Search Google for the manual for this display and read it through
  • If you’re new to this sort of technical stuff, don’t worry. Yes there are a lot of settings to make, but below are the settings I’ve inputted and although they may get ‘tweaked’ at a later stage, (especially after any suggestions from other forum members), but if you follow them then be assured, you’ll be out riding very soon.
General Settings
  • Max riding speed – 25Km per hr, wheel diameter – 700c, Imperial Units
P Parameter Settings
P187
P21 (was initially 0)
P31
P40
P512
The P1 setting was determined after following DuncanDK’s tips linked to above.
C Parameter Settings
C12C65C110
C20C71C124
C38C80C130
C40C90C142
C510C10n
So go around the bike and ensure all cables are neatly secured and if not using the thumb throttle, cap the end of the cable to prevent water ingress.
Happy ebiking.
Amndt: 26/7/20 - P2 now = 1 to correct speed reading issue and C7=1 for cruise control activation
8,598
Well done nice to here of a problem free install of the KT electronics ( as of late there have been a few where the motor/KT combo have not married well).
The difference as you mention over binning the speed controller to the current controller is so different, with the latter giving much more control of the power and it needing to be used without compromising the speed.
Reactions: Bikes4two
Bikes4two
1,036
445
Havant
Thanks @Nealh - whilst your here ...... :cool: . There's a peculiarity with the speed as displayed on the LCD5 - if after pedalling up to speed I then just stop peddaling to idle back to near stopping, I've noticed that the LCD5 MPH readout drops to zero long before the bike slows down - this was particularly evident as I have a standard Cateye cylometer on the handlebars too.
It's not an issue at all but I am curious as to why this should be - the Bafang motor fitted has an internal speed sensor - is it that the controller switches off power to the motor and therefore the internal speed system is de-energised?
davell
154
64
Doncaster
bikes4two, any idea of the physical size of this controller box? I’m also looking to change from a ‘speed control’ type controller. My bike also has all Julet connectors and this one looks ideal of it will fit in the compartment in the base of the frame.
3,993
It's either because you haven't set P2 to 1 or you don't have a speed sensor in your motor, in which case you need to fit an external sensor. With P2=0, it picks up the speed signal from the motor halls. When the motor stops, your speed signal will stop too. P2=1 means it picks up the speed signal from a speed sensor with one pulse per revolution. In the rare case that your motor has 6 magnets to operate the speed sensor, you'll get 6 times the speed shown, so you know to change p2 to 6.
Bikes4two
1,036
445
Havant
I didn't actually measure it TBH but @Seajay gives the dimensions of the Pendleton one as 92mm L x 46mm W x 20mm D in the post here, and @Nealh gives the sizes of 15A and 17A controllers as 86 x 52 x 31 or 94 x 61 x 35 respectively in his posting here.
The boxes for these type of controllers look to be fairly common if the pics in various ebay listings are anything to go by and the above dimensions given by @Nealh for the 15A controller I used (86 x 52 x 31) seem about right.
Bikes4two
1,036
445
Havant
@vfr400 - setting P2=1 solved the speed reading issue - now my knowledge extends to knowing my Bafang motor has one speed magnet - thank you very much.
Yours steep on the learning curve :cool:
expressodave
Jul 1, 2023
@Bikes4two Hi, made an account just to post here!
First of all, thank you ever so much for posting a thorough log of what you did to your Somerby, you inspired me to have a go. I've got one too but it bit the dust recently as the display became waterlogged and failed. On reading about all the sagas people have trying to find the matching replacement (there are several that all look the same but aren't!) I decided to go for the same upgrade as you.
I have a question regarding a throttle implementation if you have time - do you know how I can be sure to set it up in a road legal way (limited to low speed with cut out if you stop pedalling)? Have you had any issues?
3,350
It's not guaranteed because some resellers get some with weird software, but for most you can make the throttle completely legal in the way you suggest. With P4 = 1 and C4=0, the throttle only works when pedalling. With C4=3, you get additional up to 6km/hr without pedalling. Both are legal.
carlbikekits
43
@Bikes4two how do you find the gearing on the Pendleton? I converted one to electric and I find that I'm out pedalling the gears very quickly. That is, I seem to pedal faster than the bike expects and so above a certain speed (say 12 mph approx) I'm pedalling but no torque, no gain.
I get that it is a shopping bike and so the gearing isn't the same as a mountain bike, for instance. Wondered what your experience was on your Pendleton? Thanks
Cadence
283
214
I researched the Somerby with a view to buying one and converting it for my wife to use.
It seems that the gearing on the Somerby is different to the eSommerby.
The current Somerby has a 7 speed 14-28T freewheel with a 36T chainset. The eSomerby has 8 speed 13-32T and 38T chainset.
I think older eSomerby models had a 7 speed 11-28T freewheel, but it was changed due to quality problems.
Either way, your top gear (probably 14T rear and 36T front) is much lower than the electric version. If you fit a bigger front chainset you will have to ditch the chainguard, but you could fit an 11-28T freewheel:-
for Bicycle DNP 7-Speed Screw-on MTB Bike Freewheel Nickel Plate 11-28T | eBay
There were reports of quality problems with these but apparently more recent ones are better. I have one fitted on one of my bikes and it's been OK so far.
This will improve things, but you still might find it a bit low-geared. The one on my old mountain bike allows me to pedal comfortably up to around 23mph, but that is with using the 11T rear sprocket and the biggest ring on a 48-38-28T triple chainset. Now I've converted it I only ever use the smallest four rear sprockets (11, 13, 15, 18T) and the 48T front chainring, but the rest are there as an "insurance policy" in case the electric kit fails out on the road.
This is one of the reasons why I have bought a Pendleton Brooke to convert instead. It has an 8 speed 11-34 cassette and 48-38-28T chainset on 26" wheels.
3,350
All you need is a DNP 7-speed freewheel with 11T top gear, which you van get from Aliexpress. the bottom gear size is not so important, so you can get whichever one you want. To keep them working, you need to put an occasional squirt of 3-in-One oil into the pawls.
Bikes4two
1,036
445
Havant
Hi Clive,
We sold the eSomerby 'on' a couple of years back but as far as I recall the 'out of the box' gearing was fine for my wife who happily cycled between 10-15mph without 'spinning out'.
What motor did you fit to the bike and is it a torque sensing or cadence sensing? If the latter, I'm wondering if the motor is simply whizzing you up to and holding you around 12mph without you having to do much?
RedDon
9
After we fitted the above replacement kit we were getting 17 mph and found it easy to cycle at that speed, cadence was around 50 which isn't high if you're a cyclist but maybe if you don't cycle regularly?
Sturmey
654
357
68
Great post. What length 1-4 Cable 1400, 725 or 295?
You need a long cable as it runs from the top of the high head tube down to the bottom bracket and then back up the extra seat tube cavity and then out to the rear rack. Any extra slack can be curled up at the rear rack stays. Measure it as it looks awful if the cable is not long enough.
