Phase wires
Andy-Mat
784
147
73
Hi. this is the connector i need John
I looked on ebay UK for you and found this:-
https://www.ebay.co.uk/itm/Molex-Connector-6-Pin-Circuit-Standard-093-093-6-Way-Crimp-Plug-Terminal/282373731678?hash=item41bec9355e:m:m7POyPczfQM_qscJrz431tg:rk:8:pf:0&var=581499979216
Ebay is the best place to buy for single connectors, but I recommend you to buy two, in case of accidents.
There is a special tool from molex for crimping, but I have got away in the past, with similar connectors, with pliers and a soldering iron!!
best of luck
Andy
danielrlee
1,219
631
Westbury, Wiltshire
torquetech.co.uk
best of luck
Andy
Although a suitable alternative, that isn't the same connector the OP is searching for.
As mentioned above, search for 'motorcycle connector' and you'll find what you need.
Andy-Mat
784
147
73
I believe you, but why not supply a suitable link then? I am sure that would be for the OP most helpful!
When I searched, I got this, which was far less than helpful:-
https://www.google.com/search?client=firefox-b-d&ei=kztTXNvGAc77kwXWpZSQBQ&q=molex+motorcycle+connector&oq=molex+motorcycle+connector&gs_l=psy-ab.12..0i30.85142.85142..88191...0.0..0.83.83.1......0....1..gws-wiz.nf6HpiKil6E
If you know exactly how to find the part, please do so!!
Molex connectors have/had usually got part numbers, moulded on them somewhere, usually on both parts, though some copies from the far east will not have that....though I have to admit that it is some years since I had anything to do with Molex parts....Maybe they have changed their processes?
regards for a great day
Andy
3,376
56
DJ706-2.8-11/21 are the ones fitted to all KT and likely a lot of other controllers.
When you was down last week you should have taken a pair John as I have 5 or 6 pairs.
If you use another similar connector you will have to change the controller side as well.
Check your inbox John (top right), I have messaged you.
3,455
1,114
No need for a connector. It's cheaper and more reliable to solder the wires. When does anyone ever need to disconnect one except to check whether they have a bad connection? When by some chance, there's a blue moon and flying pigs, and you find a reason to disconnect, the wire cutters can disconnect just as quick as a connector.
anon4
574
86
28
GB
If a controller burns out or throttle, pas, display break it's quicker to replace. A lot of stock connectors are crappy metal that corrodes, I stopped having issues when I replaced my hall connectors with gold plated ones. Also if one gets tugged for any reason it may get unplugged rather than breaking, although this is more true of phase and power lines than it is of flimsy hall wires
3,455
1,114
That's interesting because I had a similar but different experience. I've been repairing electric bikes for many years using the same methods, and I noticed that since I put my prices up, like you, I haven't had a single issue with of any of the repairs, so one could conclude that the price of the repair might be the key factor for reliability. What does everyone else think? Should I increase my prices further to make doubly sure of reliability because I don’t want to spoil my 100% record?
