Polution Masks
0omo0
20
11
40
Sanderstead Surrey
can anyone recommend a pollution mask that is good and that allows you to breath properly?
I have purchased 3 so far, 1 cheep one from ebay and 2 from amazon. I find they are either useless with glasses or i cant breath in them sufficiently when i am cycling. any recommendations gratefully received.
6,733
LeighPing
2,547
1,945
The Red Ditch
Looks real polluted where he,s tryng it...???
@Zlatan At times it's polluted with bugs, midges and other summer critters.
Pollution takes many forms. :)
@0omo0 I probably don't push myself enough to feel any breathing restrictions in that mask. It's a Godsend when the bugs come out in the evening though. :)
It was a really cold evening when that video was done. Starting at around 6 seconds you can see my frozen breath. That'll give you an idea on airflow restrictions with the particular mask, compared to the ones you had.
0omo0
20
11
40
Sanderstead Surrey
I cycle into central London every day for work which is why I'm asking. As during rush hour the traffic sinks. I wouldn't be asking if i was in the country side
Reactions: LeighPing
LeighPing
2,547
1,945
The Red Ditch
In that case, I wouldn't really know much. Googling came up with some positive reviews on this mask. It's quite expensive though. Good luck in finding something suitable.
http://totobobo.com/
LeighPing
2,547
1,945
The Red Ditch
Thankyou i will give that a try it sounds good
Worth a try. But maybe it'll still be stuffy. I found this reviewers comment of interest;-
All the above are passive masks and the uzers still need to exert lung pressure to overcome the filtration resistance to air flow. You should try this : http://www.ecbreathe.com which is an active powered adaptor for N95 masks. It uses battery power to overcome the filtration and the user would not feel any discomfort/stuffiness with the use of the mask. It supplies up to 700 litres of flitered air per hour.
jonathan75
794
213
Hertfordshire
I'd be nervous about that as it doesn't seem to have an FFP rating on the website I can find.
The only one I can recommend is a 3m 9322 (or other 3M FFP2 aka P2 disposable with identical design - there may be one). I get them for about £1.50 on eBay; they've got excellent fit - which as LeighPing rightly implies is important; they've got good flow; and they're FFP2 rated which means they *allegedly* catch a lot of diesel particulates - FFP3 will catch more (I've got a feeling FFP2 won't cover the <2.5micron (micron?) super-small particulates, poss the intermediate 5 micron too) but FFP3 won't be as breathable.
Sadly there's a message here: adequate protection means no cycling because of too-little flow. Ergo don't do stuff in traffic which makes you breathe heavily. I don't know what side-streets are like in terms of particulates etc.
  • Useful
jonathan75
794
213
Hertfordshire
Oddly enough a scientific study found that filtration was worse if you have bad 'fit', i.e. having a beard/stubble would tend to be highly significant for filtration (as well as of course bad fit design, and too low a protection factor of filter).
