Possible mods for my new bike.
BALDYMONSTER
51
52
Stirling
So I'm buying a 250w Dillinger fat bike.
The handlebar display is a Dillinger C965.
Can the C965 be hacked/modded for a bit more speed on private ground?
I'm presuming fitting a larger front chain ring will reduce acceleration but add some top speed.
Answers on a postcard to this very post please.
Thanks in advance.
BALDYMONSTER
BALDYMONSTER
51
52
Stirling
I do know this and that is why it would only be used on private land where I have permission, which I do.
Kinninvie
907
415
Teesdale,England
250 watts,offroad and with fat tyres probably wont have the power to go faster than the set limit anyway especially if you weigh more than 14 stone.
Putting a bigger chainwheel on could even make it go slower.
Rik D
22
10
56
Cardiff
Yes wont make much difference with that weight power ratio , and could cause knee problems
8,218
A new controller or shunt mod won't increase speed but will give more torque.
48v would give up to 25% more speed, though any controller needs to be15/16a rated max.
If existing controller is 15a it may work or go pop, If so a 48v one would be needed but then compatability with the c965 might be an issue.
Ailx47
United Kingdom
If you
If you battery could discharge 30 amps and you got a 15amp controller then it's only discharging half but if you had a higher amp controller then you will have more torque and abit more speed I had 20mph on my old 36v 8ah battery now with 48v 20ah battery I get 30mph that's with shunt mod
