printer advice
stumpy150
319
143
Yorkshire
my wife is self employed and is looking for a cheap mono colour wifi printer to print off her invoices etc..
I have a couple of hi res' canon photo printers which is proving expensive at £15 a cartridge ( wont use refills as they ferked up my past printer )
So any recommendations on a good cheap mono laser printer or similar..??
thanks in advance..
6,723
Terry1100
44
17
64
I agree with the advice here about a mono laser - but I'd stick with the Canon brand if I were you - there are i-SENSYS models around the £100 mark
derf
1,007
766
54
I third mono laser, much much cheaper in the long run. incidentally does anyone know of a good cheap 3d printer that has a hot bed (i.e. can use recyclables) and a big space?
tillson
5,253
3,197
Another vote for mono laser. I purchased a Brother DCP something, about 3 years ago. The original toner cartridge lasted nearly two years and the current high capacity cartridge cost £80. It's a good reliable printer. I wouldn't use a squirty ink type again after using this printer.
Alan Quay
2,351
1,076
Devon
In my case I need to print A3, so I use Canon inkjets with compatible inks from eBay. Last set of cartridges was £10 for 15 (I was able to chose what colours, so I got all black)
I have used compatible carts for 10 years now, never had a problem.
Sent from my HTC One_M8 using Tapatalk
tillson
5,253
3,197
I found ink jet to be OK as long as you keep using them. If not used for a while, I found that the print quality suffered.
Reactions: Alan Quay
