I am having a problem inflating the tyres of my KTM and my wife's Freego Eagle, both of which have "slimed" tubes. I use a Leyzene Classic Floor pump with a threaded connection to the Schrader valves on both bikes. The problem seems to be caused by the slime causing too much pressure for the threaded connector to screw on and is particularly bad with the rear tyre of the Freego, so much so that I had to hold the connector in place with both hands while my granddaughter operated the piston (no mean feat when the pressure is approaching 60 psi!).
Previously I had a Topeak Joe Blow turbo pump with the clamp-on type connector which simply blew off the valve whenever I started pumping.
Has anyone else experienced this and if so how did you overcome it? As a last resort I could fit new tubes without slime however I like the added protection.
Any comments or advice welcome.
Jim
Jim
