Problem with front of donor bike rattling
jonathan75
785
208
Hertfordshire
Hi, would anyone please know what's going wrong here? Something seems to be loose. I've posted a YouTube video link below. It's a Montague Urban I'm hoping to electrify. Thanks, Jonathan
Andy-Mat
1,545
348
73
I agree with vfr400, it looks as though someone has loosened it, and not tightened it and adjusted it correctly afterwards.
Its simple to do.
Or a bearing has collapsed, though I have myself never ever heard of that, then you will need two new bearings of the correct size, and the knowledge to remove the originals and replace with new. But that is a very long shot!
Andy
Reactions: jonathan75
Andy-Mat
1,545
348
73
Thanks @Andy-Mat and @vfr400. It sounds like a Bike Repair Person job to me. I wouldn't know where to start!
I agree.
Hopefully its a standard size, and that it can be obtained quickly.
For a Bike shop, they are probably in a position to replace/adjust the parts, with their eyes closed.;)
But as its also a safety issue, then your assessment is by far the best way to proceed.
Best wishes for a rapid repair.
Andy
Kwozzymodo
148
29
59
Lincolnshire
Is that an aheadset? Can’t quite tell from the vid. If it is, you can loosen the stem bolts and the tighten up the top cap bolt (not too tight though; 5-6nm should do the trick). That should pull the forks up snug with the headtube and spacers, without placing any excess force on the upper and lower bearings. Whilst you are doing this (or outsourcing the work), take a peak at the upper and lower bearings and races to check they are not worn. Replace if the look dodgy - only a few quid, so worth it.
jonathan75
785
208
Hertfordshire
Thanks Kwozzymodo - that's really good advice, despite your good description I'm so 'green' that I think I'd better get a pro to do it, but I'll mention what you said, including to check the bearings and races. Appreciated.
