Re tricycle conversion
Richard jarvis
Oct 7, 2018
I have recently purchased a tricycle
It’s a folding frame the make is wolf
It has 24 inch wheels I’m looking for a front drive
I’m partly disabled and struggling to pedal
Thanks in anticipation
peter.c
1,613
493
thurrock essex
Hi
I now have two tricycle builds in progress one with a mid drive in the picture and another step thru with a 28 inch front wheel cyclocity 250 watt front hub in steel forks with a disc brake on the front and rear
its turned into a major build the only original part left is the frame it needed bearings drive shaft bottom bracket tyres etc it appears that most parts are available [try mission tricycles very helpfull ] it is now half the original weight and has mega range 27.ah battery
2,835
I see Yose has a 24" front wheel kit.
https://www.amazon.co.uk/YOSE-POWER-Conversion-36V250W-Electrique/dp/B07DWV19C8/ref=lp_9709887031_1_10?srs=9709887031&ie=UTF8&qid=1540989148&sr=8-10
I've never used Yose but they sound OK from comments I have read.
I would recommend Woosh but they don't seem to have any 24" front drive units.
Installation should be fairly straight forward. If you have integrated brake/gear levers or hydraulic brakes you will need extra sensors rather than the sensor brake levers supplied with most kits.
