You also need to check if your bike has the correct threads and lugs. Two M5 lugs brazed onto the seat stays for the horizontal arms, two M5 threads by the dropout for the vertical struts.
If you don't have the lugs on your bike, you can get a seat post clamp with rackmount but you do need the holes to bolt the vertical legs.
Good racks have sliding struts and built in spacers to adjust the height to suit your wheel and keep the vertical struts vertical.
I am thinking about buying this but it is 2hr drive from me.
I'm just trying to figure out if I could get a rack for it because without a rack the bike would be no good for me to ride to work.
I don't know anything about the correct lugs. But looking at the frame it looks like it might be difficult to fit a rack?
Tricky! Depending on how high you have the saddle, you might be able to fit a beam rack like this one: https://www.halfords.com/cycling/bike-accessories/bike-pannier-racks/topeak-rx-beam-rack---v-type-346871.html That would limit the weight you could carry, so check its listing. If there was a quick release seat clamp and the saddle was too low to give access normally, you could release the seat post and swing it round to get access...
Very odd design, with the motor there it looks as if it is specially created to prevent use of a rack!
Checking images for 'izip ebike' on Google It looks as if it comes from 2006.
You may well have difficulty replacing the battery; and if it is the original it is probably dead or nearly dead.
The perfect quick-mount rear rack system attaches to MTB full suspension seatstays or hardtail MTB without rack eyelets. This one-size-fits-all front rack features an innovative top plate that adjusts to level independent of the seatstay angle. Integrated QuickTrack® system allows Topeak...
Woosh, do you have the internal measurements for this, my rack (non Woosh bike) has broken and I am also looking for a replacement. Can I buy this mail order?
A seatpost rack with quick release might just fit depending if there is a gap with the saddle raised to your height. But still would have to be removed when you need to remove the battery unless you can get a more innovative design as suggested..
Those rear seat tub rack things aren't designed for a heavy battery, eventually probably the clamp will give way due to vibration/fatigue.
A QR seat clamp will work but depends if the op is going to leave it for any length of time locked up somewhere ? Eventually the seat/post might get nicked then the next low life will see it as being stripped down and something else might get removed and so on.
The Op would have at least three options, a lot of them with the Currie motor were 24v.
1. Buy another battery they are still available.
2. Get it recelled by Jimmy.
3. Buy a Silverfish battery with the fitting kit and swap them over.
I don't think the OP was asking to move their battery location, just to fit a pannier that wouldn't obstruct the removal of the battery in its current position.
The QR seat clamp could be released and the whole rack swung round 90 degrees or so with the seat post, to allow the battery to be lifted out. It'd probably need any bags taken off first, but it could be done.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
