Like the sound of this. Bought 2nd hand Torq 2 weeks ago, only 2 weeks old and made a considerable saving.
I carried out Flecc's throttle mod last week and used some nice soft chunky grips to help cushion the shock coming through the bars. It works well, and now only need to use my thumb and forefinger to control the throttle. Might try the cramp buster mob, but would also like to use chunky grips, therefore wonder if I might need the wide Crampbuster?
Slightly different throttle thread. The only fault I found on the torq I bought was the rather brittle flimsy plastic the throttle assembly is made of was badly cracked by over tightening the grub screw to secure it to the bars. Looks like only the plastic is threaded and not the metal part of the assembly, bit of a design fault I reckon!
I repaired this with the careful application of epoxy resin adhesive. I applied vaseline to the areas where I did not want the adhesive to go, so that I did not lock the throttle or the grub screw. So far so good, but I think a new throttle might be in order. Has anybody had a similar problem?
