Replacement ebike battery
johnboy
15
Alan Quay
2,351
1,076
Devon
All the batteries I have bought from BMS come with Anderson powerpoles on. It's an easy job to swap your bullets for Anderson. Normally they put a pair in the pack with the battery.
Anderson's are much better long term.
johnboy
15
Do you know if I buy the battery in the link will I simply be able to attach pannier rack and just plug in the new battery? There seem to be other cables attached to the battery can I ignore these?
Alan Quay
2,351
1,076
Devon
After you change bullets to Anderson's you just plug in. It's only two wires for the discharge, and another two for the charger.
johnboy
15
Do you know if there is a battery with rack with a higher capacity than 14.5ah suitable for bafang bbs01 250w?
