I have a new lithium battery arrived today, it fits on its side in battery case so all ok. but now i need to know, about wiring it all up. I will need to fit the charger plug tight in hole as its slightly narrower. But I believe the 2 other wires IE: discharge red and black goes to discharge pins in picture Red to positive + pin and black to negative - pin
but how do i wire up the 2 fuse wires in picture
I assume the battery needs a full charge as red light is on the charger. and its been on 1 hour so far so imagine it does
