I would be grateful if anyone could help me identify appropriate replacement components to fix my pedelec.
The bike is a Viking Ego-24. This model is sometimes also called a Hopper, or a Tesco Hopper. There's a photo of it below in case it has other names and it helps to identify it. It has a 24V battery. It's about 7 years old.
The problem it has it with starting it up. As shipped, switching it on was always simply a case of pressing the On button on the handlebar controller when the key in the ignition is in the On position. This stopped working a couple of months ago.
There is a workaround I've discovered, which is pressing the On button on the handlebar controller simultaneously with switching the key in the ignition from the Off position to the On position. This usually sees it power on, though it can involve several attempts before it works, so it isn't really a lasting solution.
While the key in the ignition is in the On position, the handlebar controller occasionally flashes for a fraction of a second, even if the bike is switched off, which it never used to do.
I'm pretty certain the problem isn't with the battery or with the battery mount that includes the ignition key unit, as I have tried replacing these and the same problem manifests. There is no obvious wearing or looseness in any of the wiring. I have taken the controller unit apart, and it shows no signs of water ingress or damage. I have also tried unplugging and re-plugging in all the cords coming out of the controller box.
I can only think that the problem is either with the motor controller, or with the handlebar controller, and that replacing both should have a fair chance of solving the problem. The issue is that I'm not sure what replacement components I need to buy.
The controller itself is labelled as manufactured by Octopus. I can't find a direct replacement for it - that manufacturer appears to either no longer exist or has changed its name. I have tried emailing the UK distributor for Viking bikes, Avocet, asking if they sell (or can point me in the direction of) a replacement component but they have not responded.
The cables coming out of the controller are as shown below:
There are no shortage of listings for controllers for (24V) brushless motors and handlebar controllers on both ebay or Amazon. But that's the point where I get stuck - I don't know which if any are compatible with my bike. Would this work? Alomejor Electric Bike Brushless Controller con Waterproof LCD Display Panel 24V/36V/48V 250W/350W Controller Kit for Electric Bike Scooter: Amazon.co.uk: Sports & Outdoors If that wouldn't be suitable, are any forumites aware of any controllers that can be used as direct replacements on Viking Ego bikes?
Many thanks in advance for any help you can offer.
