Ribble Bikes
helentdavies
25
9
Anybody got a Ribble bike? Their showroom in Clitheroe looks pretty cool. They've got the weight down on their e bikes.
helentdavies
25
9
Groupset
SRAM Apex 1x11 Speed
Shifters - SRAM Apex 11-Speed Flat Bar.
Brakes - Shimano BL-MT201/UR300 Hydraulic Disc.
Chainset - SRAM Apex 1 GXP 42T.
Bottom Bracket - SRAM GXP Team Press Fit BB86.
Cassette - SRAM PG-1130 11-42T.
Chain - SRAM PC-1110 11-Speed.
Rotors - SRAM Centreline 6-Bolt 160mm.
Rear Derailleur - SRAM Apex 1 11-Speed Long Cage.
Drive System
Control Button - iWoc Trio Handlebar Mounted Remote Control.
Hub - MAHLE Ebikemotion X35+ M1, 36V/250W.
Battery - Panasonic 36V/250Wh, 18650GA-10S/2P.
Wheelset
Wheels - Mavic Ksyrium S Disc UST, 12x100F/12x142 Bolt-On Rear.
Tyres - Schwalbe G-One, Tubeless-Ready, 700x40mm, Black/Tan.
Frameset
Frame - 6061-T6 Aluminium, Heat-Treated, Seamless Weld.
Forks - Full Carbon Monocoque, Tapered Steerer.
Headset - LEVEL H56 Integrated, Black.
Finishing Kit
Bars - LEVEL Urban 6061 Alloy, 640mm, Black.
Stem - LEVEL 2 3D-Forged 6061 Alloy, Black.
Grips - LEVEL Urban Lock-On, Black.
Seatpost - LEVEL 1 6061 Alloy, 27.2mm, 350mm, Black.
Saddle - Selle Royal Vivo Ergo Sport, Black.
Included Accessories
Pannier Rack - Ribble Alloy, Black.
Bell - Ribble, Black.
Lights - Ribble FL300/RL150 (300/150 Lumen) USB LED.
Mudguards - Ribble 46mm Reinforced Plastic, Black.
Pedals - Flat Plastic, Black.
Weight
Approximate Weight (not inc accessories) - 15kg/33lbs.
MontyPAS
390
148
Groupset
Drive System
Wheelset
Frameset
Finishing Kit
Weight
Price??
mike killay
3,012
1,627
Does having a lightweight ebike make much difference?
My bike is loaded with panniers full of various things and weighs a lot. It has a large comfortable saddle, mudguards, lights telescopic forks etc.
Still goes up hill very well with a minimum of assistance only required for the steepest parts(I have a throttle)
8,219
Model name ?
Depends on how it rides unassisted and how athletic the rider is, the 250wh battery battery for a good fit rider should be capable of 30 miles. With 2S 10P of GA cells one would suspect about 12a max from the controller other wise they won't last too long if asked to draw high current.
The lighter weight will provide good handling and feel but that weight will go up 2 or 3kg if you have to add any accessories.
My Gravel bike is about 10.5kg and about 15.5kg on a ride with e-kit 2 x 208wh batteries & accessories, range is approx. 50 miles.
8,219
It does for a small battery and a light rider and they just feel a bit nippier in handling terms.
Reactions: helentdavies
helentdavies
25
9
I think so yeah. I try to ride as much as possible without assistance, so the lighter the better. I suppose it depends on your particular needs. Also for getting on and off the carrier on the car, even though I take the battery out, I can still struggle on my own.
helentdavies
25
9
Model name ?
Ribble Hybrid AL e Step Through
Fully Loaded Edition £2399
helentdavies
25
9
Just out of interest really. Not thinking of getting one. They get good reviews and are made fairly locally AND you can get custom colours of your choice lol.
richtea99
434
283
If you like to ride with no assistance for a significant proportion of your ride, then absolutely yes!
If you want a bike that feels 'normal' then yes again.
The Ribble is roughly the equivalent of my Orbea Gain, with both having an ebikemotion system, and about the same weight.
The spec is higher than mine (i.e. fully loaded), so I'd say it's a decent bike at £2,399 if the above two points mean a lot to you.
mike killay
3,012
1,627
Thanks.
Actually, I have no interest at all in riding a 'proper bike' and always use assistance.
Reactions: MontyPAS
richtea99
434
283
Thanks.
I wrote 'feels normal' not 'proper bike' - i.e. it acts & feels close to an unassisted bike, which might also include lifting it into the house, turning it over to fix punctures, not just cycling it.
But I'd certainly agree a Ribble isn't for you. ;)
Reactions: robert44
