S06S Power Setting
awol
1,145
346
My S06S controller tapers the power in when throttle is applied for a gentle speed up.
Is there a setting to change the length of time the S06S controller takes to get up to full requested power,
I mean shorten the power tapering-in effect ?
Mine seems to take a bit long.
Normally, it's fixed in the microprocessor software. I've never heard of one that can be changed.
awol
1,145
346
No problem, Ive just had my first go at soldering it's shunt and upped it's amps by 4 amps which may help me feel the power a bit more.
That's not too much is it for an S06S ?
Thanks d8veh.
It should be fine, but it's always a good idea to have a feel from time to time after you've done it just to make sure that it doesn't get too hot.
