Wisper Seat won't come out?
anonymous
138
15
Hi,
I put the seat in, and now it doesn't even want to come out. I was using a suspension seat before. It's a Wisper 806 torque. Does anyone know how I can get it to come out?
6,315
i would take it to a lbs as will have the tools to better remove it.
6,315
when it is out put some grease inside the frame so it wont get stuck again ;)
6,315
RobF
4,732
2,311
Carbon assembly paste is recommended for seat tubes.
It is grease with granules in so it helps grip and also prevents seizing.
Ordinary grease will do the latter but might cause problems with the former.
6,315
yes,if you have a carbon seat tube and frame you need carbon grip lube to install it so it will not move i doubt the op has either nor do you pmsl:)
MikelBikel
591
285
Penetrating fluid and reasonable heat to free it. Local Bike Shop put white lithium grease on mine but prob coz its cheap and close to hand. It goes yellow with age so wipe off any excess. But wth, Copaslip or as above any grease thats ok with alloy and the paint will do. A little Vaseline goes a long way ;-)
RobF
4,732
2,311
Carbon assembly paste is not just for carbon bicycles.
It does the job as I outlined for alloy and steel as well.
So pmsl all you like.
RossG
1,628
1,646
Heating is still the best and cheapest way to get the seat pin out. If you can't get the lid off a marmalade jar hold it under a hot tap for a few seconds, the heat expands the metal on the lid faster that the glass so it comes off easily.
Guaranteed it works every time.
RossG
1,628
1,646
Just realized there's your answer. Take the bike outside lay it on it's side and pour hot (not boiling) water over the seat tube, the tube should expand enough to pull the seat pin out.
Wisper Bikes
6,227
2,190
68
Sevenoaks Kent
Hi,
Is this sorted now or can I help?
All the best, David
Reactions: artspeck
