Sparking when I plug the battery in to charge.
Turkeylegs
68
34
Darlington
Hi guys
Every time I plug the little plug into my cyclotricity battery to charge it sparks. The charger isn't switched on at the plug.
Is this normal ?
Steve UKLSRA
318
293
Porthmadog
www.ukbusas.org
Yes...power the charger up before connecting to your battery
  • Useful
Reactions: LeighPing
Turkeylegs
68
34
Darlington
Ok ill give that a try next time , thanks .
Just curious but iv never had to switch the charger on before plugging into something before, is there a reason why this is needed on these batteries?
12,253
73
It's not the battery it's the charger. There is a capacitor built into the output of the charger. When you connect it in, there is 36 v in the battery and 0v on the capacitor so there is a blast of current out of the battery to charge up the capacitor.
If the charger is on, it will be at 42 v and the battery at 36 , for the difference is little and anyway the charger cannot supply much current, so no spark!.
Turkeylegs
68
34
Darlington
I tried it tonight and worked a treat. And with work and weather I've been unable to use it, so wondered if just leaving it on charge will help equalise it? Or does it have to be depleted too?
Just use your battery when you ride your bike and charge it when you get home. It doesn't make a lot of difference whether you do lots of small charges or one deep one. The only things to avoid are leaving you battery too long before charging when it's empty, and leaving on the charger too long after it's charged
  • Useful
Turkeylegs
68
34
Darlington
And iv I read cyclotricity instructions saying switch on the battery when charging, why would this be? Iv been charging with it off and seems to charge normally?
That's probably a carry over from some batteries that had the switch between the charger and the battery, so you couldn't charge with it switched off. You can ignore that.
If batteries are poorly made, they sometimes need to be balanced. The balancing happens when it gets fully-charged, so leaving it on charge for a long time will help to balance it. The best is to measure the voltage as soon as you take off the charger. 42.0v is fully balanced, so no need to leave it on any longer. Anythying down to 41.6v is nothing to worry about. It'll sort itself out in time. For 41.5v and lower, try a single 12 hour charge and see if the voltage increases. Make sure that your voltmeter is reading correctly. The charger jack, should read 42.0v
  • Useful
Turkeylegs
68
34
Darlington
Sorry to be a pain but what setting do i put the meter on? I never did learn how to use it. And do I just touch the little pin inside the small charging plug and do i need to switch the battery on while doing this ?
Turkeylegs
68
34
Darlington
If I knew how to? Iv tried all settings and touched the tiny pin in the socket the charger plugs into and getting no change to all zeros on the multi meter.
wheeliepete
2,047
755
Devon
You need to put the black prong on the outer edge of the jack at the same time to measure the voltage-this can be quite tricky as there is not a lot of room and you don't want the prongs to touch each other. It would prob. be much easier to measure the voltage on the outlet side of the battery.
  • Useful
wheeliepete
2,047
755
Devon
Without seeing a photo of the plug/socket I can't be sure which slot you are referring to. If you have 2 contacts marked + and - then yes put the prongs on them.
  • Useful
wheeliepete
2,047
755
Devon
That's fine, nothing to worry about. You may find after a few charge/discharge cycles that the voltage rises to 42v.
