Hi Indalo,Overlander, couldn't you save a wedge of cash by buying something from the Kudos or Tonaro ranges, (just by way of example; not a recommendation) given what you say about a dodgy knee and poor roads in your part of the world?
I struggle to imagine how much the Storck bike does that a whole host of other much cheaper machines can't but I haven't ridden any of those. Perhaps I'd be surprised?
Regards,
Indalo
Hi Scott,Hi Ian,
It would look like your own shop is the nearest dealer to me. Would ordering an unrestricted bike take longer than just the standard bike? What is the actual difference between the uk and export bikes in terms of assist?
Regards
Scott
Regards,
Indalo
Hi Eddie,Tappy, Is there anywhere to test ride one in London?
Regards,
Indalo
Hi Scott,My big problem with the cheaper bikes is they only come in one size fits all. I am just over 6ft 4" and if i want to cycle i need a frame that fits. The reason they get away with tiny frames on electric bikes is they expect the motor to make up for poor posture due to a bad fitting frame. But i will try and use the bike without the motor 80% of the time so need it to be a good fitting frame. Currently i ride the Trek FX + with a 25" frame and my FW Evans is just under 25". But i can use a 23" as a minimum, so a 19" or less would be awful for me.
