Strange disc brake phenomenon
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
I've experienced a strange behaviour from a set of Tektro Auriga Comp hydros since I acquired the bike they came with about 18 months ago. The bike in question also features regenerative braking via a DD hub motor, which means I hardly ever use the physical brakes, hence why I ignored the issue for so long.
I can't remember how the brakes performed when I bought the bike (couldn't have been too bad since it passed an unpowered test ride), but the rotors were warped to buggery so I replaced them immediately. I also performed a brake bleed as part of the initial bike prep. I didn't replace the pads since they looked pretty fresh and as if had plenty of life left in them.
Here's the problem – Under normal circumstances, braking is pretty pants. It takes quite a bit of effort to stop, more than hydros should anyway. However, if I carry out a few high speed stops (30mph to 0) and get some heat into the rotors, the braking performance is amazing.
Why would this be? Could the pads be contaminated and are causing lacklustre low-temp performance? Yes, I could have replaced them by now, but didn't in case the whole brake system needs replacing.
Anyone got any ideas?
6,319
you could try cleaning the pads or just replace them for new ones.
JuicyBike
1,671
527
Derbyshire
Spray on Isopropyl Alcohol onto the rotor surface and wipe it off. Best to keep away from the brake pads, lungs, little children etc.
Quite expensive, especially in specialist bike shop form, but is available on Fleabay.
I would say that your pads are probably getting glazed through lack of use if you have regen braking. I think you need the constant hard braking to wear off the glazed surface. Also, winter salt seems to have a big effect on them. Giving then a good clean after it's all gone improves them a lot.
Different pads work better under different circumstances. As you go quite fast, try sintered ones.
6,319
and the rotors?
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
I haven't tried cleaning the rotors yet.
Is acetone a suitable alternative to rubbing alcohol? I don't have any rubbing alcohol, but I can see my GF's nail varnish remover from where I am sitting :)
EDIT: Scrap that, it's got a moisturising oil additive to make your brake rotors nice and soft. I've just found a bottle of surgical spirit, that I'll use instead.
30,375
Your local chemist will have isopropyl alcohol and can supply a small bottle of it. They'll ask what it's for but will be happy with your answer.
My opinion is also that it's the brake pads that need replacing, but clean the rotors before using the new pads.
stumpy150
319
143
Yorkshire
I use brake / clutch cleaner spray from Halfords - the same that you use on the car...give the rotors a quick spray and remove the pads and give them a rough up with some emery cloth on a flat surface ... should do the trick.
I had issues with my Tektro brakes last September while on holiday. On return I replaced the tektro pads with organic shimano pads and replaced the rotors with shimano Zee .. I am now going to replace the calipers and pipes with shimano in the next couple of weeks
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
I've cleaned the rotors with surgical spirit and removed the glazed surface of the pads with some abrasive. I only did the pads previously, so hopefully doing the two together will solve the issue.
I'll report back on Monday after my afternoon run to the Post Office.
Thanks guys.
30,375
If there was a film of any substance glazed onto the rotors, the pads wouldn't grip, but sustained contact could make the substance heat up and soften, causing binding between pads and rotor.
6,319
you also dont want hot rotors as will warp them the hotter they get
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
Disappointing. Cleaning my pads & rotors made no difference to the braking performance. Admittedly, it was only a short journey of a couple of miles and may not have had bedded in again yet. I'll give them a little longer before I replace the pads, but I dont think they'll improve.
stumpy150
319
143
Yorkshire
Don't be so negative !
You could either give up , take the bike to the local charity shop and make it a donation OR.....
You could have another go at sorting it out OR....
You could take it to your local bike shop and let them take a look at it ???
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
Strange reply? Not sure if my post was a little unclear, but I meant that I don't think the existing pads will improve. New ones are what I'll try next.
I certainly won't be selling my bike or giving it to the charity shop and I've never had a bike shop fix any of my own bikes in my whole life!
stumpy150
319
143
Yorkshire
It was a tongue in cheek reply meant in good humour
If you have tried several methods to try and sort your brakes and you haven't had much luck then I would either get a mate to have a look at them - sometimes a second head helps and also try out your local shop ..... For the amount of time you have have spent on the bike plus the potential cost of another set of pads it may be worthwhile for the cost of an hours labour at the bike shop for them to take a look at it ??
Last suggestion - have you checked the calipers pistons for movement ?
I recently sorted a mates motorcycle who had been having issues with poor brakes - new pads had been fitted and allegedly serviced by a main dealer - turned out the Pistons were corroded and partially siezed ..,,, New pistons and seals sorted them out.
Best of luck
Alan Quay
2,351
1,076
Devon
Did you rough them up with sandpaper?
Sent from my HTC One_M8 using Tapatalk
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
Just thought I would update this thread for completeness sake.
I ended up purchasing two sets of replacement pads, but didn't do anything with them for weeks. Having now replaced the old pads and carried out a bedding in procedure, the brakes are back to how they should be and now give great performance. I imagine they'll probably last for the life of the bike now considering how infrequently they are used.
Thanks all for your help and suggestions.
