I made this video a while back. They do make a good difference, especially when going cross country. Are they worth the money.. For me, the answer would be yes.Coming from a full suspension mtb and now riding a hard tail mtb will I notice a big difference with this combination fitted , are they really worth the money
Then again, I found that a cheaper seatpost also does a good job.Coming from a full suspension mtb and now riding a hard tail mtb will I notice a big difference with this combination fitted , are they really worth the money
Indeed.Thank you I never go off road it’s just the smallest bump or pot holes sends the seat slamming into my butt cheeks lol
I have two bikes (emtb & mtb) with the sun tour posts and Lidl saddles. I wouldn’t be without them Off-road.Coming from a full suspension mtb and now riding a hard tail mtb will I notice a big difference with this combination fitted , are they really worth the money
I can confirm the oxygen s cross mk11 mtb 2020 seat post dia is 30.9 and not 31.6 for any owners**** it arrived and only don’t fit should be 30.9 and was told I needed 31.6
Expensive error**** it arrived and only don’t fit should be 30.9 and was told I needed 31.6
This is exactly what I doi must admit to buying the smaller option (27.2mm) and using seatpost shims if required to fit a larger frame. My thinking was that all my seatposts fit all my bikes![]()
Never assume, measure and double check. If not sure buy/use a Vernier, even a steel tape measure/rule would have shown 31.6 to be over size.**** it arrived and only don’t fit should be 30.9 and was told I needed 31.6
ive today had to order another this time 27.2 and yes ordered a shim that will go fromExpensive error, can you just return it for the correct one, especially if it was the vendor who told you that you needed a 31.6 dia.
I managed to get the correct post width for my cube after looking up the spec online and then measuring....Unfortunately I ordered a 400m post as I thought all for one and the cube mechanic who built my bike just cut the original post down to size. Gung-ho I decide when it arrived I’ll just do as cube did and cut the post down. All was going well until the last couple of mill to cut when bang-wallop-crash. Ffs I hadn’t realised the post was spring loaded from the bottom of the stem and I’d cut right through a plastic spring guide , I had presumed the carrier at the top was the spring! One ruined post , pissed off owner and another £65 for the correct post with 350mm stem. Definitely worth buying though , my bum certainly rides the bumps better now even on the original cube seat.Expensive error, can you just return it for the correct one, especially if it was the vendor who told you that you needed a 31.6 dia.
