Tsdz2 into a Voodoo zobop fs
peter.c
1,611
491
thurrock essex
Found a shop soiled Voodoo Zobop 20 inch frame at the right price, it is newer model the colour is brighter in real life :cool:
Removed the bottom bracket and the Tsdz2 slides in ok , the problem is the anti rotation device on the rear of the motor
Time to make a bracket to fit on the side mounts started with the 33mm hole saw and a piece of mild steel as a mock up to see if it works
:mad: the frame is different to the older model so my templates are no good , rain and darkness :oops: stop play
Yes i noticed the rear shock has been fitted upside down but it still passed the safety check:(
TJS109
112
48
76
Glos
I have noticed that some people solve this problem by rotating the motor clockwise until the motor stops on the frame and then fit without a bracket. Since the motor rotates in that direction this makes an effective stop. No idea if it would work with your bike but might we worth a look
peter.c
1,611
491
thurrock essex
That's the problem with early retirement to much spare time :) might get if completed tomorrow, if she who must be obeyed, does not find me another more urgent project or little job to do
Reactions: Bodgeitnscarper
peter.c
1,611
491
thurrock essex
Done after a test ride a bit more to shave off the battery case under full compression:oops:
250watt;) simple/ basic conversion ,no added frills with min added weight :pIMG_20190822_185001520.jpgIMG_20190822_185008700.jpgIMG_20190822_180737492.jpg
Bodgeitnscarper
43
Looks great Peter,
Can the battery move up the frame a touch to give clearance by the shock. I guess not or you would have done it already.
peter.c
1,611
491
thurrock essex
No not if I still want to be able to remove it
Both the the front and rear of the battery case have had a close encounter with the angle grinder to reshape it :eek: waiting for some soft plastic to arrive to reshape the case used gorilla tape for the test ride :)
