Unhappy surprise
Paul Wrighton
84
24
65
After less than two weeks gocycle ownership...
40079
8,788
Once local scum notice a nice bike regularly they will follow or word is put about with other local scum members, your nice GC was targeted.
Reactions: D C
Paul Wrighton
84
24
65
This much I know... I already gave notice on that garage, so this confirms that. The cupboards security is less convenient, must break down bike, but once I've upgraded per consultation I'll relax... So glad I had insurance, even if not needed this time
Deleted member 33385
I can't believe you kept it in a garage with such rubbish locks and thin doors! (All locks are rubbish when used with rubbish doors). The locks which usually feature on those doors are terrible! But as usual, thieves have used the brute force approach and have gone at the door with a long crowbar/pry - a friend of mine installed a steel door at his shop, but he made the error of installing single point locking ie one bolt into the steel frame. A few seconds with a long crowbar - they were in and away. Heavy guage steel doors with multipoint locking take far longer to break, and they usually don't try. I doubt that a DNA+ label would have put them off in the least! They don't seem to have got very far with the door peeling, perhaps they were disturbed? If they can't get in very fast without drawing too much attention, they tend to give up. But they often circle back later to try again... Repeat burglaries and burglary attempts are extremely common.
Is this garage near your home? I don't want to worry you, but I'd be mindful of anyone watching the house - it'd be easy to follow you to your home. They might think that anyone who has such a nice looking bike may have more nice looking things. They're much less likely to attempt a break-in if you have an alarm system, but you probably already know that.
MontyPAS
390
148
My wife is letting the bike live in the garden for a limited time.
I doubt it will be in the garden very long.
Get it safely indoors or lose it. From experience. Even with insurance you will not get back the ££££'s you invested once the insurance company have invoked the wriggle out clause.
Insurance is all well and good after the event (if said wriggle out clause is not exploited), but prevention works out far less traumatic... plus insurance as a business is mostly a scam - the (former) world's richest man Warren Buffet built his fortunes largely on insurance profits.
I doubt they would have paid out, I had a garage like that and had to fit a 5 lever lock at each of the four corners to obtain cover. You were very lucky, another few minutes and it would have been gone.
Yep, a garage door with 4 separate 5 lever locks in all four corners would be a b*****rd to get past, take too long and be very noisy business indeed on a thin garage door - it'd be like beating a large drum. They'd need two thieves with large crowbars (preferably four), to have any hope of a quick and dirty theft. Or use two car jacks at either side of the door... or they could drill hooks into the door and pull the door out of the locks using a stolen Range Rover, or tunnel up through the floor, but I think my imagination might be running slightly wild at this point. They could escape in minis.
Raboa
901
318
53
Hi, sorry to hear about that.
Kryptonite do floor anchors that you bolt to your floor and chain your bike to it.
I have one kicking about unused if you want to make me an offer.
slowcoach
174
115
I have fitted a door defender similar to this. Fortunately, our garage is next to our house and we have the advantage, if you so much as sneeze in your front garden it will be seen by neighbours with nothing better to do. But that does have its advantages.
British Made Black Powder Coated Garage Defender Master - Best Garage Security
30,848
My neighbour's garage had one of these and it was easily beaten.
The thieves merely crowbarred the garage door a couple of inches inwards at the base to beyond the lock's base plate, then crowbarred the base plate up to wrench it's fixing bolt and insert out of the concrete.
They left the lock and bolt etc as evidence of how they did it.
richtea99
443
286
These are good - I have one. In a line of garages, it will make a casual thief go for the next garage. However, for a pro tealeaf it may suggest there's something worth stealing. Tricky.
Paul Wrighton
84
24
65
Believe it or not the garage is scheduled for demolition!
Bike is basically in house since there's zero access to garden.
I plan on making the coal hole cupboard VERY secure. And that will be all I can do.
Incidentally I had a shriek alarm 100db padlock on the bike and although I can't know, its possIble that was the thing that caused them to desist. Although round the block from me there are other flats near that garage.
Edward Elizabeth
136
192
Buckinghamshire
It's pointless trying to target harden a garage in a block. If the door looks too much like hard work they'll go in through the roof.
Get it elsewhere, locked in a proper building with good security and decent natural surveillance.
Paul Wrighton
84
24
65
As I said, it's at home now. Garage is being demolished and I have vacated it. Where I'm improving security is on a cupboard to the front of my hiuse
Gringo
1,352
843
Northampton
A few too many years ago a mate of mine had a remotely located garage,
One morning he found his the door bent like the op’s, that afternoon I fitted two hasps and staples to the concert floor and the steel door, one at the bottom of each corner. A few weeks of feeling comfortable passed and then on opening the secure door he found no bike ? the bricks had been carefully (and quietly) removed from the back wall !
As far as the thieves were concerned it was worth all the effort for a shiny new Harley Davidson ;)
