Vulcan infrared sensor
Timbarge
14
Hello,does anyone know how to test the sensor,I can't see any light on the sensors but maybe you can't! The display woks fine but no motor response ,there is five volts on the sensor board from + to - pins 1 and 3.
cyclebuddy
1,553
736
Beds & Norfolk
It's infrared (IR). You can see it with a camera.
Timbarge
14
Some infra red is visible ,I take it the sensor isn't, thank you for replying.
You were right about that sensor,I decided to check the display as I noticed it came off ,the contacts were corroded ,cleaned them and tested the the wheel sensor by turning the wheel ,it worked.
